08-24-2016 11:54 PM - edited 03-01-2019 08:21 AM
Hi my friends;
I have a questión which is the diference of the output show vpc consistency-parameters global. In cluster VPC one dont show the Interface-vlan admin up and Interface-vlan routing in both switches , but in cluster two show me it in the both switches. In the last cluster VPC tree Interface-vlan admin up and Interface-vlan routing is showed in the Nexus with role primary but in the role seondary dont show it. what is the reason maybe the NX-OS versión ? the model of the nexus? . I dont kown the configuratión are identical in all switches.
Cluster VPC one:
Cluster VPC two:
Cluster VPC tree:
Best regard,
Marco.
09-26-2016 05:47 PM
Hi Marco,
I don't see any discrepancy noted here?
In general, if the L3 configuration (SVIs) are identical across both the vPC peers, "Interface-vlan admin up" and "Interface-vlan routing" gets populated and should be identical on a given vPC pair.
If you still see some discrepancy even after validating we have same SVIs configured on both vPC primary and secondary, then it should be flagged as an issue.
Sunil.
