08-25-2016 04:32 AM - edited 03-18-2019 12:06 PM
Hello Team,
IP phones not registering in cme.
After getting ip address from the cme router(isr4321) looking for registration,but not registering??
What all details i have to check for registering ip phone to cme router.
Does the isr 4321 router flash need ip phones firmware is compalsory ??
downloaded the image from cisco,but I am not able to copy firmware of cisco ip phone to the isr4321 flash??
Anybody Knows the reason??
ISR4321#copy startup-config tft
ISR4321#copy startup-config tftp:
Address or name of remote host []? 192.168.50.75
Destination filename [isr4321-confg]?
%Error opening tftp://192.168.50.75/isr4321-confg (Timed out)
KIndly help...
08-25-2016 04:48 AM
conf t
ip tftp source-interface <BLAH>
end
08-25-2016 06:05 AM
Leo,
Thanks for the comment.
two ip phones are showing similar DN?
Show run is mentioned below...
ISR4321#show run
ISR4321#show running-config
Building configuration...
Current configuration : 2801 bytes
! Last configuration change at 07:07:13 IST Thu Aug 25 2016
version 15.4
no platform punt-keepalive disable-kernel-core
hostname ISR4321
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
card type e1 0 1
enable password password
no aaa new-model
clock timezone IST -5 30
ip dhcp pool IPPHONE
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
option 150 ip 192.168.2.1
subscriber templating
isdn switch-type primary-net5
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sip
registrar server expires max 86400 min 3600
voice-card 0/1
no watchdog
license udi pid ISR4321/K9 sn FDO20250QYN
redundancy
mode none
controller E1 0/1/0
pri-group timeslots 1-31
interface GigabitEthernet0/0/0
description IPPHONE-NETWORK
no ip address
negotiation auto
interface GigabitEthernet0/0/0.10
encapsulation dot1Q 10
ip address 192.168.0.9 255.255.255.0
interface GigabitEthernet0/0/0.20
encapsulation dot1Q 20
ip address 192.168.2.1 255.255.255.0
interface GigabitEthernet0/0/1
ip address 192.168.50.1 255.255.255.0
negotiation auto
interface Service-Engine0/1/0
no ip address
interface Serial0/1/0:15
encapsulation hdlc
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0/0/1
control-plane
voice-port 0/1/0:15
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
telephony-service
max-ephones 30
max-dn 45
ip source-address 192.168.2.1 port 2000
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn 1
number 001
ephone-dn 2
number 002
ephone-dn 3
number 003
ephone-dn 4
number 004
ephone 1
mac-address 40F4.ECEF.E1D5
type 7942
button 1:2
ephone 2
mac-address 40F4.ECEF.D112
type 7942
button 1:2
ephone 3
ephone 4
mac-address 40F4.ECEF.CF3C
type 7942
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password password
login
transport input all
line vty 5 15
password password
login
transport input all
network-clock synchronization automatic
e
