IKEv1 policy/ Phase 1 lifetime matching rules on ASA (9.x)
tickermcse76
According to the documentation:
Note: An IKEv1 policy match exists when both of the policies from the two peers contain the same authentication,
encryption, hash, and Diffie-Hellman parameter values. For IKEv1, the remote peer policy must also specify a lifetime
less than or equal to the lifetime in the policy that the initiator sends. If the lifetimes are not identical, then
the ASA uses the shorter lifetime.
Does the very last statement mean the ASA will effectively downgrade its policy lifetime value to match the remote peer for that specific connection only?
For example suppose I have the following policies (for simplicity all other settings match on both sides with lifetime being the only variable):
crypto ikev1 policy 10
lifetime 60
crypto ikev1 policy 20
lifetime 120
crypto ikev1 policy 30
lifetime 200
Suppose a remote peer has a lifetime setting of 100.  This would match policy 20.   Would the ASA "downgrade" its lifetime value to 100 only when communicating with this remote peer?  Or would there be a mismatch of 100 and 120; in which case a new policy needs to be created with lifetime 100?
pjain2
yes the ASA will downgrade the lifetime to 100 when communicating with this remote peer. there is no mismatch in the lifetime.
when the tunnel comes up, in the "show crypto ipsec sa" you can check the lifetime it is using for that tunnel which is going to be the lowest value for the two configured ends.
Would that be true even for non-Cisco devices?  Have a situation where ASA is set for 24 hour lifetime, and remote peer is non-Cisco and set for 18 hours.  The tunnel resets every 6 hours, which is the difference in the lifetimes.
yes it is true even for non cisco devices. the default phase 1 lifetime on ASA is 24 hours. the rekey will happen  using the phase 2 lifetime. please check for that on both the ends for the rekey timer.
