08-25-2016 11:54 PM - edited 03-19-2019 11:31 AM
at the moment I am setting up a Lab for the first time. It will include CUCM, IMP and Unity 11.5.
At the moment the thing that I am struggling with is the SIP-Trunk between my CUCM and IMP. I was following the chapter "Cisco Unified Communications Manager configuration for integration with IM and Presence Service" but somehow it does not work still. I followed the instruction step by step.
Can you maybe give me a hint why the SIP-Trunk does not come up? SIP-Profile and Security Profile looks good to me. I also added the cucm as the presence gateway at the CUPS and all the necessary Services are also running. I am not using DNS at the moment.
Thanks in Advance
Stefan
Solved! Go to Solution.
08-29-2016 07:38 PM
What do you mean by "come up"? The presence publish trunk doesn't use sip options ping so there is no monitoring state.
08-29-2016 07:38 PM
02-14-2017 07:41 AM
Hi Jonathan,
thank you very much for that information.
Problem has been solved.
Best Regards
Stefan
08-30-2016 06:30 AM
+5 to Jonathan as the SIP trunk to IMP will show "Unknown - OPTIONS Ping not enabled" which is expected. To see if it works check presence status of user when she/he goes off-hook on properly configured IP phone to make sure it shows status of "On the phone" to other observers.
