The SG200-08P is a gigabit switch, is the port connecting to the upstream switch running at 1GB Full Duplex on both ends?
Unless they are uploading/downloading large files, 1GB should be ample for a handful of users.
Check the stats on the link to ensure there are no errors and confirm that its running at near 100% capacity, there may be another issue instead of the link actually being saturated.
Assuming you do in fact need more bandwidth and its a Layer 2 link then your only real option is link aggregation but this needs to be enabled both ends.
Adding a second link without Link Aggregation will just give you failover as STP will likely block one of the paths to prevent a loop.
