SG300 Intervlan routing not working
bipin.varghese
I am new in Cisco
I have 2xSg300-28PP Switches
Switch 1 is L3 mode and Sw2 is L2 mode.
Created 2 vlan. Default vlan IP: 192.168.45.11. other vlan IP: 192.168.47.1
Sw1 port 26 connected to Sonicwall TZ400. TZ400 is the firewall and default GW with IP 192.168.45.1
All ports are in Access mode in both vlan. Port 26 is in Trunk mode.
vlan ports assigned: Port 11, 12, 13, 23-all are untagged..Remaining all ports are in vlan1untagged ports.
connected two systems in port 1 and port 11. Given static ip to both. (192.168.45.111 for one and 192.168.47.20 for the other)
I cannot ping between PCs.
When I tracert 192.168.47.20 from the first system, found it send all packets to the default GW.
Can anybody help to solve the issue..
I read your post few times but can't put together a picture,if you have a diagram it'll be helpful to understand your topology to anyone here in the forum,perhaps few more config snippet as well
Could you ping both your default gateways for corresponding VLANs?have you checked whether you have appropriate return routes on the firewall?
Prabath
***Please rate all the useful posts***
-Prabath
