Jabber Directory Lookup Multi UDS - Jabber version 11.7
Currently we have two cluster CUCM and each cluster use different domain, first domain is cp.co.id and second domain is cpi.sg. Jabber local and jabber MRA work fine in each site. My question, is it possible for Jabber via MRA from cluster cp.co.id to search user (lookup contact) from another cluster? Our cluster both use UDS for directory services because we need to use jabber from MRA.
First cluster cp.co.id :
CUCM : 11.5
IMP : 11.5
Exp-C : 8.8.1
Exp-E : 8.8.1
Second cluster cpi.sg :
CUCM : 11.5
IMP : 11.5
Exp-C : 8.8
Exp-E : 8.8
Please advise to fullfil this need,
Jaime Valencia
No, that's not possible, you can only use one UDS cluster, the same one to which your device is registered for directory lookups/directory search.
You'd need to build a custom directory that polls the info from UDS, or is a proxy for both for your endpoints.
java
if this helps, please rate
Hi Jaime,
could you please explain more about "You'd need to build a custom directory that polls the info from UDS, or is a proxy for both for your endpoints."?
Or if you have any documentation or guide to do those scenario it would be great :)
Ovindo
