08-30-2016 05:33 AM - edited 03-18-2019 06:19 AM
I am running TMS 15.1.0 and trying to upgrade to 15.3.0 ..
I am logged in with admin priv. getting the error 1670 unable to load module ... Error Code 5 ???
Any ideas ??
VR
C
Solved! Go to Solution.
08-30-2016 09:35 AM
That would make sense, usually a good idea to turn of any anti-virus during an install/upgrade just in case so to avoid issues such as this, if it is the anti-virus that is causing the error.
08-30-2016 06:00 AM
Hi ,
did u try to run the 15.3 exe as "Run as administrator" by doing right click.
lastly, u can also verify the MD5 checksum of downloaded 15.3 file.
regds,
aman
08-30-2016 08:54 AM
I am RDT in and the OS is Windows 2008 R2.
I get the same error running as Admin .. I am logged in as Admin also.
The MD5 checks are good for both 15.2 and 15.3 files.
08-30-2016 06:52 AM
In addition to Aman's suggestions, try making sure the server has all of it's Windows Updates, maybe something is dependent.
What OS version are you running?
08-30-2016 09:19 AM
Looks like might be McAfee blocking some DLL's ... working it ...
My other network isn't having the problem ... 15.2.1 working.
08-30-2016 09:35 AM
08-30-2016 10:01 PM
Had to move the install file to C:\ to get it to install. McFee rocket scientist software developers block install in a profile other than root admin. Even if personal profile has admin rights. ...
08-30-2016 10:33 PM
thanks for sharing the update.[+5]
regds,
aman
