08-30-2016 06:40 AM - edited 03-14-2019 04:29 PM
Hi Folks, I've had a question posted to me and as I cant actually access the application for a while, I thought it'd be best ask you.
The end supervisor needs to generate 2 reports :-
%age of calls answered within 2 minutes
Number of calls abandonded with 30 seconds
UCCX version is 11.X. Does anyone know if these are available or will we need to install an advanced CUIC server rather than the standard one?
Paul.
Solved! Go to Solution.
08-30-2016 10:51 AM
Unfortunately co-resident CUIC that comes with UCCX does not provide either of these reports. Hence, you will need a standalone CUIC server with premium license installed on it and create these reports then. Below is the link that provides list of all the available reports and their fields within co-resident CUIC:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cust_contact/contact_center/crs/express_11_0/user/guide/UCCX_BK_UD562201_00_uccx-report-description-guide-11.html
Deepak
08-30-2016 10:51 AM
Deepak
08-30-2016 10:56 PM
Brilliant - just what I wanted.
Many Thanks indeed.
08-30-2016 11:02 PM
Glad that I was able to help Paul and thanks for marking the Correct Answer.
Deepak
08-30-2016 11:10 PM
Hi Deepak, I haven't started to look but would the premium license that is installed on the current UCCX cluster suffice or is it an additional one?
Paul
08-30-2016 11:12 PM
That has nothing to do with the license installed on UCCX be it Premium or Enhanced. You will need to purchase premium license for CUIC and install it there only and not on UCCX.
Deepak
