ICM Max Nodes in ICMS File - Monitored Label Value
SEAN NILSEN
Level 4
Level 4
In reference to hitting the 999 node limit, I am trying to recall where to look in an exported script to find the Monitored Label count.
I thought it was right near the top of the file but I can't remember which exact element in the arrays it is.
Does anyone know which value to look at in the ICMS output?
Thanks!
SEAN NILSEN
Level 4
Level 4
I remembered how this works now.
This line near the top of the ICM Exported script (usually line ~2):
CVisScript {-1 7 67 2 {0} {0} {38 ScriptStart {2 1 0 3 1}
The third number after the CVisScript, "67" in this example, is the Monitored Node count.
The number immediately before the ScriptStart, "38", represents the number of actual nodes in the script.
