08-30-2016 12:41 PM - edited 03-08-2019 07:13 AM
I have 4 Cisco IP Phones but only 2 Switch Ports available, can i connect 2 Cisco IP phones on one port i.e. connecting second Cisco IP Phone to a Data Port available on Cisco IP Phone , is it possible ? if so what configuration is required ...
08-30-2016 12:58 PM
You can enable PC Voice Vlan Access at the phone level for the phones in the beginning of the chain. Dont forget the AC power brick for the 2nd devices.
Please rate useful posts and mark answers correct if applicable.
08-30-2016 01:07 PM
you mean configuring Both Access and Voice Vlan with Voice Vlan Id ?
08-30-2016 12:59 PM
Hi Irshad;
Till now only 1 IP phone (with or without PC) can connect on 1 switch port. If you want to connect 4 IP Phone then you need to purchase an extra PoE switch.
Thanks & Best regards;
08-30-2016 03:09 PM
I've never heard of what you are attempting to be successful.
If you have computers in the occupied access ports, move phones into them and switch a computer off the phone.
08-31-2016 02:45 AM
Hi Irshad,
Depending on the phone type you are using(most phones have PC ports except few models) you can daisy chain the second phone but you'd have to supply power to the secondary phone.this is usually not a recommended practice see here.
Cheers,
Prabath
