08-30-2016 08:53 PM - edited 03-08-2019 07:13 AM
When would you want multiple routers connected to the same switch?
For what purpose?
Solved! Go to Solution.
08-31-2016 02:13 AM
Hi Josh
One concept we have , on remote sites have a backup vpn router and primary mpls router connected back into one core L3 switch with multiple blades running using IGP and 2 routers use BGP at the front connecting back to HQs , this gives us hardware redundancy and ISP redundancy which can be must if critical traffic coming from the remote site
08-31-2016 02:13 AM
Hi Josh
