08-31-2016 10:36 AM - edited 03-08-2019 07:15 AM
hello everyone,
I have a stack of 3 3850s. Does anyone know how to review a crashfile for when a switch crashes. I cannot determine why the switch crashed, but it did leave behind a crashfile.
sh ver
Switch 1 uptime is 10 hours, 59 minutes
Uptime for this control processor is 11 hours, 6 minutes
System returned to ROM by Power Failure at 17:05:00 pdt Fri Jul 29 2016
System restarted at 23:34:15 pdt Tue Aug 30 2016
System image file is "flash:packages.conf"
Last reload reason: Power Failure
08-31-2016 02:02 PM
It isn't due to a crash.
Post the complete output to the command "dir".
08-31-2016 02:23 PM
Yeah, I saw that. dir crashinfo did produce a crashinfo file. Will it produce the file even if there is a power outage?
I will get you the info when I get back. I've just seen a case where it said "power failure" but the actual switch had hardware problems where we ended up replacing it.
08-31-2016 03:54 PM
It shouldn't be a file but two sets of sub-directories. If date & time is correctly set then it will tell when the file(s) were created.
Kindly post the complete output to the command "dir".
No.
