Warning message
Can I use Jabber on MAC the same way as in any other device like Microsoft Lync?
Aug 31st, 2016
Hey with Microsoft Lync I could connect with my personal computer from home using Lync without needing more information other than my log in info.  For your solution to download it it seems I need a contract number or add the service, etc.  It should not be as straight forward as having the client and log in info.  I mean in Android it works without any issue and I had just to install the app.  In my workplace I connect to the Intranet but from my mobile as long as I have internet I can connect to my jabber.  Maybe you handle this differently but I would expect this should be as easy as Lync.  Thanks.
Varundeep Chhatwal Thu, 09/01/2016 - 01:50
  • Cisco Employee,
Could you please share the exact info you are requesting so that i can check how much i can help you with that. i didn't understand your request from above description.
felipe.martinez... Thu, 09/01/2016 - 05:56
In a few words.  Is there any easy way to obtain the Jabber for MAC client?  Thanks
