09-02-2016 01:54 PM - edited 03-17-2019 08:01 AM
Hello I´ll appreciate any help about this situation:
CISCO3900 router with (C3900e-UNIVERSALK9-M), Version 15.1(3)T2 and VWIC3-2MFT-T1/E1 card is forming a SIP Trunk with an Asterisk PBX. Trunk is working ok,I can receive a call from PSTN through E1 card but caller ID shown in end user extension is always "unknow".
What I´m trying to do is to receive a DID XXXX from E1 and route that call to an extension registered in Asterisk PBX. End user should be able to see in phone lcd screen the caller number(from PSTN).
IOS conf:
num-exp YYYY ZZZZ where YYYY is received DID and ZZZZ is the extension number registered in Asterisk PBX
dial-peer voice X voip
description to Asterisk PBX
destination-pattern ZZZZ
session protocol sipv2
session target ipv4:XXXX.XXXX.XXXX.XXXX:5060
session transport udp
dtmf-relay rtp-nte
codec g711ulaw
clid strip
no vad
Asterisk PBX trunk conf:
type=friend
host=HHHH.HHHH.HHHH.HHHH !ip address of cisco router
dtmfmode=rfc2833
disallow=all
allow=ulaw
insecure=port,invite
port=5060
qualify=yes
IOS DEBUG:
[output ommited]
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=<Calling number here>
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=YYYY
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreason=0 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
1280269: Aug 31 13:12:10.595: //-1/4501E49AAC48/CCAPI/cc_api_call_setup_ind_common:
Interface=0x204B310C, Call Info(
Calling Number=<Calling number here>,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=YYYY(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=11, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Sub Called(TON=Unknown, NPI=Unknown, Data=, Length=1)
1280270: Aug 31 13:12:10.595: //-1/4501E49AAC48/CCAPI/ccCheckClipClir:
In: Calling Number=<Calling number here>(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
1280271: Aug 31 13:12:10.595: //-1/4501E49AAC48/CCAPI/ccCheckClipClir:
Out: Calling Number=<Calling number here>(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
1280272: Aug 31 13:12:10.595: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1280273: Aug 31 13:12:10.595: :cc_get_feature_vsa malloc success
1280274: Aug 31 13:12:10.595: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1280275: Aug 31 13:12:10.595: cc_get_feature_vsa count is 19
1280276: Aug 31 13:12:10.595: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1280277: Aug 31 13:12:10.595: :FEATURE_VSA attributes are: feature_name:0,feature_time:658108720,feature_id:159556
1280278: Aug 31 13:12:10.595: //185680/4501E49AAC48/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=<Calling number here>(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=YYYY(TON=Unknown, NPI=Unknown))
1280279: Aug 31 13:12:10.595: //185680/4501E49AAC48/CCAPI/cc_process_call_setup_ind:
Event=0x21A4B0F8
1280280: Aug 31 13:12:10.595: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number YYYY
1280281: Aug 31 13:12:10.595: //185680/4501E49AAC48/CCAPI/ccCallSetContext:
Context=0x273A3934
1280282: Aug 31 13:12:10.595: //185680/4501E49AAC48/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 185680 with tag 11 to app "_ManagedAppProcess_Default"
1280283: Aug 31 13:12:10.595: //185680/4501E49AAC48/CCAPI/ccCallProceeding:
Progress Indication=NULL(0)
1280284: Aug 31 13:12:10.595: //185680/4501E49AAC48/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=26, Params=0x273B0108, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
1280285: Aug 31 13:12:10.595: //185680/4501E49AAC48/CCAPI/ccCheckClipClir:
1280286: Aug 31 13:12:10.595: //185680/4501E49AAC48/CCAPI/ccCheckClipClir:
Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Network, Presentation=Unavailable)
1280287: Aug 31 13:12:10.595: //185680/4501E49AAC48/CCAPI/ccCallSetupRequest:
Destination Pattern=ZZZZ, Called Number=ZZZZ, Digit Strip=FALSE
1280288: Aug 31 13:12:10.595: //185680/4501E49AAC48/CCAPI/ccCallSetupRequest:
Calling Number=(TON=Unknown, NPI=Unknown, Screening=Network, Presentation=Unavailable),
Called Number=ZZZZ(TON=Unknown, NPI=Unknown),
Redirect Number=, Display Info=
Account Number=, Final Destination Flag=TRUE,
Guid=4501E49A-6EDD-11E6-AC48-BC9A9C20B09A, Outgoing Dial-peer=26
1280289: Aug 31 13:12:10.595: //185680/4501E49AAC48/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-ani= !<--------YES this field is empty I think CID should be here
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=2
cisco-anisi=3
dest=ZZZZ
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
1280290: Aug 31 13:12:10.595: //185680/4501E49AAC48/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x206A8FAC, Interface Type=3, Destination=, Mode=0x0,
Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Network, Presentation=Unavailable),
Called Number=ZZZZ(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=26, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
1280291: Aug 31 13:12:10.595: //185680/4501E49AAC48/CCAPI/ccIFCallSetupRequestPrivate:
1280292: Aug 31 13:12:10.595: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1280293: Aug 31 13:12:10.595: :cc_get_feature_vsa malloc success
1280294: Aug 31 13:12:10.595: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1280295: Aug 31 13:12:10.595: cc_get_feature_vsa count is 20
1280296: Aug 31 13:12:10.595: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1280297: Aug 31 13:12:10.595: :FEATURE_VSA attributes are: feature_name:0,feature_time:658103568,feature_id:159557
1280298: Aug 31 13:12:10.595: //185681/4501E49AAC48/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
1280299: Aug 31 13:12:10.595: //185681/4501E49AAC48/CCAPI/ccCallSetContext:
Context=0x273B00BC
1280300: Aug 31 13:12:10.595: //185680/4501E49AAC48/CCAPI/ccSaveDialpeerTag:
1280301: Aug 31 13:12:10.595: //185681/4501E49AAC48/CCAPI/cc_api_call_proceeding:
Interface=0x206A8FAC, Progress Indication=NULL(0)
1280302: Aug 31 13:12:10.597: //185681/4501E49AAC48/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:ZZZZ@XXXX.XXXX.XXXX.XXXX:5060 SIP/2.0
Via: SIP/2.0/UDP HHHH.HHHH.HHHH.HHHH:5060;branch=z9hG4bK33AC68
From: "unknown" <sip:HHHH.HHHH.HHHH.HHHH>;tag=4F2389B4-7E
To: <sip:ZZZZ@XXXX.XXXX.XXXX.XXXX>
Date: Wed, 31 Aug 2016 18:12:10 GMT
Call-ID: 4501E49A-6EDD11E6-AC4DBC9A-9C20B09A@HHHH.HHHH.HHHH.HHHH
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 1157751962-1859981798-2890448026-2619388058
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1472667130
Contact: <sip:HHHH.HHHH.HHHH.HHHH:5060>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 301
v=0
o=CiscoSystemsSIP-GW-UserAgent 7389 765 IN IP4 HHHH.HHHH.HHHH.HHHH
s=SIP Call
c=IN IP4 HHHH.HHHH.HHHH.HHHH
t=0 0
m=audio 18030 RTP/AVP 0 100 101
a=rtpmap:0 PCMU/8000
a=rtpmap:100 X-NSE/8000
a=fmtp:100 192-194
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
1280303: Aug 31 13:12:10.597: //185681/4501E49AAC48/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP HHHH.HHHH.HHHH.HHHH:5060;branch=z9hG4bK33AC68;received=HHHH.HHHH.HHHH.HHHH
CSeq: 101 INVITE
Server: FPBX-2.11.0(11.20.0)
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE
Supported: replaces, timer
Session-Expires: 1800;refresher=uas
Contact: <sip:ZZZZ@XXXX.XXXX.XXXX.XXXX:5060>
Content-Length: 0
1280304: Aug 31 13:12:10.605: //185681/4501E49AAC48/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:ZZZZ@XXXX.XXXX.XXXX.XXXX>;tag=as2c641f16
CSeq: 101 INVITE
Content-Length: 0
1280305: Aug 31 13:12:10.605: //185681/4501E49AAC48/CCAPI/cc_api_call_alert:
Interface=0x206A8FAC, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
1280306: Aug 31 13:12:10.605: //185681/4501E49AAC48/CCAPI/cc_api_call_alert:
Call Entry(Retry Count=0, Responsed=TRUE)
1280307: Aug 31 13:12:10.605: //185680/4501E49AAC48/CCAPI/ccCallAlert:
1280308: Aug 31 13:12:10.605: //185680/4501E49AAC48/CCAPI/ccCallAlert:
Call Entry(Responsed=TRUE, Alert Sent=TRUE)
1280309: Aug 31 13:12:10.926: //185681/4501E49AAC48/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Content-Length: 0
1280310: Aug 31 13:12:13.564: //185681/4501E49AAC48/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Require: timer
Content-Length: 234
v=0
o=root 328334328 328334328 IN IP4 XXXX.XXXX.XXXX.XXXX
s=Asterisk PBX 11.20.0
c=IN IP4 XXXX.XXXX.XXXX.XXXX
t=0 0
m=audio 12804 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
1280311: Aug 31 13:12:13.564: //185681/4501E49AAC48/CCAPI/cc_api_call_connected:
Interface=0x206A8FAC, Data Bitmask=0x1, Progress Indication=NULL(0),
Connection Handle=0
1280312: Aug 31 13:12:13.564: //185681/4501E49AAC48/CCAPI/cc_api_call_connected:
Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
1280313: Aug 31 13:12:13.564: //185680/4501E49AAC48/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=FALSE, Tone=Null,
Tone Direction=Network, Params=0x0, Call Id=185680
1280314: Aug 31 13:12:13.564: //185680/4501E49AAC48/CCAPI/ccConferenceCreate:
(confID=0x1D641358, callID1=0x2D550, gcid=4501E49A-6EDD11E6-AC48BC9A-9C20B09A, tag=0x0)
1280315: Aug 31 13:12:13.564: //185681/4501E49AAC48/CCAPI/ccConferenceCreate:
(confID=0x1D641358, callID2=0x2D551, gcid=4501E49A-6EDD11E6-AC48BC9A-9C20B09A, tag=0x0)
1280316: Aug 31 13:12:13.564: //185680/4501E49AAC48/CCAPI/ccConferenceCreate:
Conference Id=0x1D641358, Call Id1=185680, Call Id2=185681, Tag=0x0
1280317: Aug 31 13:12:13.564: //185680/4501E49AAC48/CCAPI/cc_api_bridge_done:
Conference Id=0x11BD1, Source Interface=0x204B310C, Source Call Id=185680,
Destination Call Id=185681, Disposition=0x0, Tag=0xFFFFFFFF
1280318: Aug 31 13:12:13.564: //185681/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1280319: Aug 31 13:12:13.564: cc_api_get_xcode_stream : 4682
1280320: Aug 31 13:12:13.564: //185681/4501E49AAC48/CCAPI/cc_api_bridge_done:
Conference Id=0x11BD1, Source Interface=0x206A8FAC, Source Call Id=185681,
Destination Call Id=185680, Disposition=0x0, Tag=0x0
1280321: Aug 31 13:12:13.564: //185680/4501E49AAC48/CCAPI/cc_generic_bridge_done:
1280322: Aug 31 13:12:13.564: //185680/4501E49AAC48/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x11BD1, Destination Call Id=185681)
1280323: Aug 31 13:12:13.564: //185681/4501E49AAC48/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x11BD1, Destination Call Id=185680)
1280324: Aug 31 13:12:13.564: //185680/4501E49AAC48/CCAPI/cc_api_caps_ind:
Destination Interface=0x206A8FAC, Destination Call Id=185681, Source Call Id=185680,
Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
Modem=0x2, Codec Bytes=20, Signal Type=3)
1280325: Aug 31 13:12:13.564: //185680/4501E49AAC48/CCAPI/cc_api_caps_ind:
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=1000(ms), Fax Nom=300(ms))
1280326: Aug 31 13:12:13.564: //185681/4501E49AAC48/CCAPI/cc_api_caps_ind:
Destination Interface=0x204B310C, Destination Call Id=185680, Source Call Id=185681,
Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1,
Modem=0x0, Codec Bytes=160, Signal Type=2)
1280327: Aug 31 13:12:13.564: //185681/4501E49AAC48/CCAPI/cc_api_caps_ind:
1280328: Aug 31 13:12:13.564: //185681/4501E49AAC48/CCAPI/cc_api_caps_ack:
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=2218)
1280329: Aug 31 13:12:13.564: //185680/4501E49AAC48/CCAPI/cc_api_caps_ack:
1280330: Aug 31 13:12:13.564: //185680/4501E49AAC48/CCAPI/ccCallConnect:
Progress Indication=NULL(0), Data Bitmask=0x1
1280331: Aug 31 13:12:13.564: //185680/4501E49AAC48/CCAPI/ccCallConnect:
Call Entry(Connected=TRUE, Responsed=TRUE)
1280332: Aug 31 13:12:13.564: //185680/4501E49AAC48/CCAPI/cc_api_voice_mode_event:
Call Id=185680
1280333: Aug 31 13:12:13.564: //185680/4501E49AAC48/CCAPI/cc_api_voice_mode_event:
Call Entry(Context=0x273A3934)
1280334: Aug 31 13:12:13.564: //185680/4501E49AAC48/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x11BD1, Call Id1=185680, Call Id2=185681
1280335: Aug 31 13:12:13.564: //185681/4501E49AAC48/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:ZZZZ@XXXX.XXXX.XXXX.XXXX:5060 SIP/2.0
Via: SIP/2.0/UDP HHHH.HHHH.HHHH.HHHH:5060;branch=z9hG4bK33B1D1C
[output ommited]
Asterisk PBX debug:
[output ommited]
== Using SIP RTP TOS bits 184
== Using SIP RTP CoS mark 5
Audio is at 10046
Adding codec 100003 (ulaw) to SDP
Adding codec 100004 (alaw) to SDP
Adding codec 100002 (gsm) to SDP
Adding non-codec 0x1 (telephone-event) to SDP
Reliably Transmitting (no NAT) to <Softphone IP>:57974:
INVITE sip:ZZZZ@<Softphone IP>:57974;rinstance=b50d90a287eeb355 SIP/2.0
Via: SIP/2.0/UDP XXXX.XXXX.XXXX.XXXX:5060;branch=z9hG4bK3223a9d4
Max-Forwards: 70
From: "unknown" <sip:Unknown@XXXX.XXXX.XXXX.XXXX>;tag=as4245b513
To: <sip:ZZZZ@<Softphone IP>:57974;rinstance=b50d90a287eeb355>
Contact: <sip:Unknown@XXXX.XXXX.XXXX.XXXX:5060>
Call-ID: 7c6dda947458c58538981ad63a2650a5@XXXX.XXXX.XXXX.XXXX:5060
CSeq: 102 INVITE
User-Agent: FPBX-2.11.0(11.20.0)
Content-Length: 281
v=0
o=root 919374057 919374057 IN IP4 XXXX.XXXX.XXXX.XXXX
t=0 0
m=audio 10046 RTP/AVP 0 8 3 101
a=rtpmap:8 PCMA/8000
a=rtpmap:3 GSM/8000
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
-- Called SIP/ZZZZ
<--- Transmitting (no NAT) to HHHH.HHHH.HHHH.HHHH:5060 --->
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Content-Length: 0
<--- SIP read from UDP:<Softphone IP>:57974 --->
SIP/2.0 100 Trying
CSeq: 102 INVITE
Content-Length: 0
--- (7 headers 0 lines) ---
SIP/2.0 180 Ringing
Contact: <sip:ZZZZ@<Softphone IP>:57974;rinstance=b50d90a287eeb355>
To: "ZZZZ"<sip:ZZZZ@<Softphone IP>:57974;rinstance=b50d90a287eeb355>;tag=c591e852
CSeq: 102 INVITE
User-Agent: X-Lite release 4.9.3 stamp 79961
Allow-Events: talk, hold
Content-Length: 0
--- (10 headers 0 lines) ---
list_route: hop: <sip:ZZZZ@<Softphone IP>:57974;rinstance=b50d90a287eeb355>
-- SIP/ZZZZ-00000236 is ringing
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Content-Length: 0
SIP/2.0 200 OK
To: <sip:ZZZZ@<Softphone IP>:57974;rinstance=b50d90a287eeb355>;tag=c591e852
CSeq: 102 INVITE
Allow: SUBSCRIBE, NOTIFY, INVITE, ACK, CANCEL, BYE, REFER, INFO, OPTIONS
Supported: replaces
Content-Length: 202
[output ommited]
Solved! Go to Solution.
09-04-2016 09:00 AM
Remove the "clid strip" command from your dial-peer.
09-04-2016 09:00 AM
09-05-2016 06:32 AM
It works!
without that line CID is now delivered to extension registered in asterisk PBX.
Thank you Jonathan
