09-09-2016 08:14 AM - edited 03-17-2019 06:21 PM
The Jabber emoticons box is empty. It just says choose a Smiley.
I have uninstalled Jabber and re-installed. I checked and the emoticons library is there. The XML files are correct. The box is still empty.
I have this happening on 2 separate laptops in the office.
Anybody who has seen this or that may have a solution would be appreciated.
09-09-2016 09:19 AM
What Jabber version and what OS is it installed on? Are you registering Jabber to a server and if so, what is it and what software version is it running?
09-09-2016 09:25 AM
Its version 11.7.
It' is connecting through a server but all of the people here are connecting through the same server and this the only time I have ever seen this. As a matter of fact we have like 15 IT service desk people all over the country and its the first time any of us has seen it.
09-10-2016 05:34 PM
It appears there is something different about the installation/configuration of Jabber on those two laptops. A stare and compare of the configuration of a working laptop and one of the failing laptops should help. You might also look at the Jabber log file on a failing laptop. There might be a reference to accessing the emoticon file.
03-13-2017 09:26 AM
Were you able to fix yours? I know this is an old thread but I looked everywhere for an answer and found nothing. So I started tinkering, and figured out how to fix mine. Exit Jabber, delete (or rename) the file
C:\Users\User\AppData\Local\Cisco\Unified Communications\Jabber\CSF\History\user.db
(replace "User" with your own username)
and restart Jabber. It recreated it and the smileys are back. Hope this helps someone else someday.
03-13-2017 09:55 AM
Thanks for that update. It always helps to see whether someone's issue is solved and how.
09-22-2016 09:01 AM
same problem here. It is working fo all jabbers running on citrix desktop. Problem exist only on notebooks.
Jabber Version 11.7.0 42920
Do you have a solution for this problem in the meantime?
Best regards
Manfred
