Multiple SSIDs with 702 (standalone)
tom
Hi All
I am trying to configure an Aironet 702i (standalone) to broadcast 2 SSIDs on both radio interfaces.
The First SSID (Private) is secuered with AES and is assigned to the VLAN 1 (native VLAN)
The Second SSID (Public) is open access and assigned to VLAN 50
Router is a Draytek 2860
Switch is a Netgear M4100 with the Aironet on fa 0/1, tagged for both VLANS. And the router on Giga 0/1, untagged.
AP config is attached
Thank you
Try to remove mobility network-id and test again.
-Scott
-Scott
6 Replies 6
tom
Sorry forgot to say: The issue is not that the SSIDs are not broadcasting, they are. But whenever a device tries to connect to either SSID it fails to authenticate.
-Scott
-Scott
Hi Scott
Thank you very much for the advice.
I have removed the mobility network-id and SSID Private is now working fine but devices are still failing to connect to SSID Public.
-Tom
Never mind I think i have it now. Issue was in the settings for VLAN 50 on the switch.
Thanks for pointing out the mobility network-id though, defiantly the source of my original problem.
-Tom
Glad that was an easy fix:)
-Scott
-Scott
What is the issue you are facing ? clients are unable to connect ? Pls describe your issue
Rasika
