09-11-2016 02:33 AM - edited 03-05-2019 04:40 AM
Hi Everyone,
I want to know that If any subnet is not directly configured on ASA on any interface. This subnet is coming from another router through VLAN routing. Can I configure NAT on ASA for this subnet ?
example configuration -
interface Ethernet0/0
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
security-level 0
interface Vlan2
security-level 100
object network ASA-SW0
subnet 10.0.0.0 255.255.255.252
object network VLAN10
subnet 192.168.10.0 255.255.255.0
object network VLAN20
subnet 192.168.20.0 255.255.255.0
route outside 0.0.0.0 0.0.0.0 200.150.75.1 1
route inside 192.168.10.0 255.255.255.0 10.0.0.1 1
access-list LAN extended permit
access-group LAN in interface inside
nat (inside,outside) dynamic interface
Note: Subnet 192.168.10.0 and 192.168.20.0 is not directly configured on ASA and I want to configure NAT for that subnet also but not working.
Deepak Kumar
Solved! Go to Solution.
09-11-2016 11:27 AM
I agree that Karsten has a much better solution. But I thought that the solution with per subnet nat rule should work and wondered why it did not work. In looking a bit more closely I notice that vlan 1 security level 0 and public IP is named inside while vlan 2 with security level 100 and the private IP is named outside. This mismatch will prevent either solution from working.
Rick
09-11-2016 03:47 AM
For sure you can. This is a typical configuration where the Firewall is connected to the core-switch with a transfer-network. Only the DMZ-networks are directly connected to the ASA, but all the internal networks are connected to the core-switch.
But you don't need a NAT-rule per internal VLAN. You can configure all with one simple rule:
nat (inside,outside) after-auto source dynamic any interface
09-11-2016 11:27 AM
Rick
