FMC REST API 6.1
Answered Question
Sep 12th, 2016
  • Silver, 250 points or more
I am currently playing around with firepower rest api on FMC 6.1 and I am looking for a method to get domain name to domain id mapping. Since the specific domain id must be used in the URL to consume the api I would like to get the ID by name.
https://fmc.example.com/api/fmc_platform/v1/domain/<domainid>/<operation>
Please let me know if there is a way to do this atm. Since the api-explorer provides a dropdown to select the correct domain I think this should be possible.
kind regards
Oliver
Correct Answer by dohurd about 7 months 4 weeks ago
I did get some more insight that may be helpful:
When you retrieve the token, the domains uuids for which the user is authorized are sent in the HTTP header along with the tokens.
When you run a post to the following URI:
https://[FMCIP]/api/fmc_platform/v1/auth/generatetoken
using your API credentials (username and password), the return headers will include DOMAIN details. The example below has the domain highlighted. As Kirti said this is the domain the user is authorized to login to so it can be used to quickly and easily identify which domain you are making calls to.
Accept-Ranges bytes
Cache-Control no-cache, no-store, must-revalidate, max-age=0
Connection Keep-Alive
Content-Length 0
DOMAINS [{"name":"Global","uuid":"e276abec-e0f2-11e3-8169-6d9ed49b625f"}]
DOMAIN_ID 111
DOMAIN_UUID e276abec-e0f2-11e3-8169-6d9ed49b625f
Date Fri, 28 Oct 2016 12:45:42 GMT
Keep-Alive timeout=5, max=100
Server Apache
USER_UUID 9fcaa802-742f-11e6-940a-dcadeeddb529
Vary Accept-Charset,Accept-Encoding,Accept-Language,Accept
X-Frame-Options SAMEORIGIN
X-auth-access-token bfc90e8e-6893-4cc6-a82f-3b6579b13444
X-auth-refresh-token 6c0bbbbb-2550-47c3-a165-20c0ee28e470
global e276abec-e0f2-11e3-8169-6d9ed49b625f
Overall Rating: 5 (2 ratings)
kaisero Thu, 10/27/2016 - 11:12
After reading docs and using the API for quite some time, I have concluded that this is not possible atm or not documented... Hoping for 6.2 to fix this issue.
dohurd Thu, 10/27/2016 - 13:08
  • Cisco Employee,
I checked and its not in the 6.2 release.  I've asked about the following release. .. TBD
Correct Answer
dohurd Fri, 10/28/2016 - 05:51
  • Cisco Employee,
Accept-Ranges bytes
Content-Length 0
DOMAIN_ID 111
Server Apache
kaisero Fri, 10/28/2016 - 15:51
Thanks a lot for taking the time, I have tested it and found the domain mappings in the header of the authtoken request as you mentioned!
