09-13-2016 08:47 AM - edited 03-19-2019 11:35 AM
Dear all,
I have configured a sip trunk between an existing cme and a new cucm I have configured a pattern for the HQ numbers 1XX and 2XX and I can see it is working and the leave the branch office to CME at the HQ. debug CCSIP on The CME show that they are recieved there as attached. The problem is that may 1XX works but 2XX does not. I have also attached my config. I am trying to see which dial-peer that 2XX is matching and 1XX is not matching.
09-13-2016 10:55 AM
Enable "debug voip dialpeer" to see which dial peer is being matched.
Brandon
09-13-2016 02:16 PM
Try
show dialplan number 1XX then 2XX this will show which dial-peers are used
09-14-2016 03:01 AM
To clarify, you have a SIP Trunk between CUCM and a CME device.
You have two Route Patterns in CUCM, one for 1XX and one for 2XX, both of which point at your CME device.
1XX works fine but 2XX doesn't.
Is that correct?
