Hi.
I have rv325 as main router. I have 2 VLans:
1. 192.168.1.0
2 192.168.100.0
where the 1 vlan is the "main" lan and 2 vlan is the guest wifi network.
In 1 vlan i have DHCP enabled with some "IP&MAC binding" in that subnet (for laptops only, rest computers has static IP config).
2 vlan has DHCP enabled
The problem is when some of mobile workers go with their laptops to area, where is only guest wifi access (Vlan 2)
They can not obtain ip adress from dhcp in 2 vlan. It appears only if mac is in "binding table". The rest guest devices work great.
What can i do to give them access also to guest network?
