09-15-2016 07:24 AM - edited 03-08-2019 07:26 AM
We have a Cisco 6840 deployed with multiple 6800IA switch stacks. There is one switch stack with four 6800IA switches in the stack where switch $3 is no longer booting up. Does anyone know good troubleshooting command I can use in an attempt to diagnose why the switch may have gone down? Furthermore we are working to replace the switch, which means we will need to ensure the new switch functions as module #3 in the switch stack. Any assistance would be greatly appreciated!
Some config / show information below.
DSU-C6816-CORE#
DSU-C6816-CORE#show run
Building configuration...
Current configuration : 343358 bytes
! Last configuration change at 10:18:16 EST Thu Sep 15 2016 by mdillion-adm
! NVRAM config last updated at 08:51:31 EST Thu Sep 15 2016 by eric.allen
version 15.2
service password-encryption
service counters max age 5
hostname DSU-C6816-CORE
boot-start-marker
boot-end-marker
logging buffered 8192
no logging console
enable secret 5 $1$BLNc$aPNOafJHMFzqqKHIK3wSf.
username admin privilege 15 password 7 014B04270F3A4D08294E6F5D3525203E2530131D3A64
username abstech privilege 15 secret 5 $1$qR43$wvtua0ZFCVwMbVCXCLGZc/
aaa new-model
aaa authentication login default group tacacs+ local
aaa authorization exec default group tacacs+ local
aaa session-id common
platform ip cef load-sharing ip-only
clock timezone est -5 0
clock summer-time EST recurring
ip vrf management
ip dhcp snooping vlan 300
ip dhcp snooping detect spurious vlan 300
ip dhcp snooping
no ip domain-lookup
ip domain-name cnuadmin.cnu.edu
fex 110
description "DSU Room 133"
type C6800IA-48FPD
fex 111
description "DSU Room 116"
type C6800IA-48FPD
fex 112
description "DSU Room 145"
type C6800IA-48FPD
fex 120
description "DSU Room 224"
type C6800IA-48FPD
fex 121
description "DSU Room 209"
type C6800IA-48FPD
fex 122
description "DSU Room 203"
type C6800IA-48FPD
fex 130
description "DSU Room 312"
type C6800IA-48FPD
fex 131
description "DSU Room 303"
type C6800IA-48FPD
module 3 type C6800IA-48FPD
fex 132
description "DSU Room 322"
type C6800IA-48FPD
switch virtual domain 101
switch mode virtual
spanning-tree mode rapid-pvst
errdisable recovery cause bpduguard
errdisable recovery cause link-flap
redundancy
main-cpu
auto-sync running-config
mode sso
vlan internal allocation policy ascending
vlan access-log ratelimit 2000
vlan 1099
name Persona
vlan 4089
name BF-Guest
vlan 4090
name BF-Isolation
interface Port-channel100
description "To CAMPUS-CORE_lag.0.8"
no switchport
ip address 172.16.77.85 255.255.255.252
ip ospf authentication
ip ospf authentication-key 7 033E6D03280A776078
interface Port-channel110
description "FEX-110 (DSU Room 133)"
switchport
switchport mode fex-fabric
fex associate 110
interface Port-channel111
description "FEX-111 (DSU Room 116)"
switchport
fex associate 111
interface Port-channel112
description "FEX-112 (DSU Room 145)"
switchport
fex associate 112
interface Port-channel120
description "FEX-120 (DSU Room 224)"
switchport
fex associate 120
interface Port-channel121
description "FEX-121 (DSU Room 209)
switchport
fex associate 121
interface Port-channel122
description "FEX-122 (DSU Room 203)"
switchport
fex associate 122
interface Port-channel130
description "FEX-130 (DSU Room 312)"
switchport
fex associate 130
interface Port-channel131
description "FEX-131 (DSU Room 303)"
switchport
fex associate 131
interface Port-channel132
description "FEX-132 (DSU Room 322)
switchport
fex associate 132
interface TenGigabitEthernet1/1/1
switchport
channel-group 110 mode on
interface TenGigabitEthernet1/1/2
description FEX-111 (DSU Room 116)
switchport
channel-group 111 mode on
interface TenGigabitEthernet1/1/3
switchport
channel-group 112 mode on
interface TenGigabitEthernet1/1/4
switchport
channel-group 120 mode on
interface TenGigabitEthernet1/1/5
description "FEX-121 (DSU Room 209)"
switchport
channel-group 121 mode on
interface TenGigabitEthernet1/1/6
switchport
channel-group 122 mode on
interface TenGigabitEthernet1/1/7
switchport
channel-group 130 mode on
interface TenGigabitEthernet1/1/8
switchport
channel-group 131 mode on
interface TenGigabitEthernet1/1/9
description "FEX-132 (DSU Room 322)"
switchport
channel-group 132 mode on
interface TenGigabitEthernet1/1/10
no switchport
no ip address
shutdown
interface TenGigabitEthernet1/1/11
no switchport
no ip address
shutdown
interface TenGigabitEthernet1/1/12
no switchport
no ip address
shutdown
interface TenGigabitEthernet1/1/13
no switchport
no ip address
shutdown
interface TenGigabitEthernet1/1/14
description "Trunk To CAMPUS-CORE_ge.2.4"
switchport
switchport mode trunk
switchport trunk allowed vlan 13,1099
ip dhcp snooping trust
interface TenGigabitEthernet1/1/15
description "To CAMPUS-CORE_ge.2.10"
no switchport
no ip address
channel-group 100 mode on
interface TenGigabitEthernet1/1/16
description "To CAMPUS-CORE_ge.6.10"
no switchport
no ip address
interface mgmt0
no ip address
interface GigabitEthernet110/1/0/1
switchport
switchport mode access
switchport access vlan 50
switchport voice vlan 120
ip arp inspection limit rate 100
spanning-tree portfast edge
spanning-tree bpduguard enable
ip verify source vlan dhcp-snooping
ip dhcp snooping limit rate 100
interface GigabitEthernet110/1/0/2
switchport
switchport access vlan 106
interface GigabitEthernet110/1/0/3
DSU-C6816-CORE#
DSU-C6816-CORE#
DSU-C6816-CORE#
DSU-C6816-CORE#
DSU-C6816-CORE#
DSU-C6816-CORE#show inventory fex all
NAME: "FEX-110 Chassis 1", DESCR: "FEX-110 Chassis 1"
PID: C6800IA-48FPD , VID: , SN: FOC2018S11B
NAME: "FEX-110 Chassis 1 PS 1 Built-in", DESCR: "FEX-110 Chassis 1 (power supply type 0.0.1.100)"
PID: Built-in , VID: , SN: DCB201566Z0
NAME: "FEX-110 Chassis 1 fan-tray 1 Built-in", DESCR: "FEX-110 Chassis 1 FEX FAN 0752 4800RPM(max)"
PID: Built-in , VID: , SN: BFB1012VH-BF97R
NAME: "FEX-110 Chassis 1 1 ", DESCR: "FEX-110 1 C6800IA-48FPD 48 ports C6800IA 48GE POE Rev. 0.0"
NAME: "FEX-111 Chassis 1", DESCR: "FEX-111 Chassis 1"
PID: C6800IA-48FPD , VID: , SN: FOC2029Z4M2
NAME: "FEX-111 Chassis 1 PS 1 Built-in", DESCR: "FEX-111 Chassis 1 (power supply type 0.0.1.100)"
PID: Built-in , VID: , SN: DCB20196HC8
NAME: "FEX-111 Chassis 1 fan-tray 1 Built-in", DESCR: "FEX-111 Chassis 1 FEX FAN 0752 4800RPM(max)"
NAME: "FEX-111 Chassis 1 1 ", DESCR: "FEX-111 1 C6800IA-48FPD 48 ports C6800IA 48GE POE Rev. 0.0"
NAME: "FEX-111 Chassis 2", DESCR: "FEX-111 Chassis 2"
PID: C6800IA-48FPD , VID: , SN: FOC2029Z4M6
NAME: "FEX-111 Chassis 2 PS 1 Built-in", DESCR: "FEX-111 Chassis 2 (power supply type 0.0.1.100)"
PID: Built-in , VID: , SN: DCB20196HC4
NAME: "FEX-111 Chassis 2 fan-tray 1 Built-in", DESCR: "FEX-111 Chassis 2 FEX FAN 0752 4800RPM(max)"
NAME: "FEX-111 Chassis 2 2 ", DESCR: "FEX-111 2 C6800IA-48FPD 48 ports C6800IA 48GE POE Rev. 0.0"
NAME: "FEX-112 Chassis 1", DESCR: "FEX-112 Chassis 1"
PID: C6800IA-48FPD , VID: , SN: FOC2029Z4MQ
NAME: "FEX-112 Chassis 1 PS 1 Built-in", DESCR: "FEX-112 Chassis 1 (power supply type 0.0.1.100)"
PID: Built-in , VID: , SN: DCB20196HG1
NAME: "FEX-112 Chassis 1 fan-tray 1 Built-in", DESCR: "FEX-112 Chassis 1 FEX FAN 0752 4800RPM(max)"
NAME: "FEX-112 Chassis 1 1 ", DESCR: "FEX-112 1 C6800IA-48FPD 48 ports C6800IA 48GE POE Rev. 0.0"
NAME: "FEX-112 Chassis 2", DESCR: "FEX-112 Chassis 2"
PID: C6800IA-48FPD , VID: , SN: FOC2029Z4PQ
NAME: "FEX-112 Chassis 2 PS 1 Built-in", DESCR: "FEX-112 Chassis 2 (power supply type 0.0.1.100)"
PID: Built-in , VID: , SN: DCB20196HCM
NAME: "FEX-112 Chassis 2 fan-tray 1 Built-in", DESCR: "FEX-112 Chassis 2 FEX FAN 0752 4800RPM(max)"
NAME: "FEX-112 Chassis 2 2 ", DESCR: "FEX-112 2 C6800IA-48FPD 48 ports C6800IA 48GE POE Rev. 0.0"
NAME: "FEX-120 Chassis 1", DESCR: "FEX-120 Chassis 1"
PID: C6800IA-48FPD , VID: , SN: FOC2029Z4ML
NAME: "FEX-120 Chassis 1 PS 1 Built-in", DESCR: "FEX-120 Chassis 1 (power supply type 0.0.1.100)"
PID: Built-in , VID: , SN: DCB20196HFU
NAME: "FEX-120 Chassis 1 fan-tray 1 Built-in", DESCR: "FEX-120 Chassis 1 FEX FAN 0752 4800RPM(max)"
NAME: "FEX-120 Chassis 1 1 ", DESCR: "FEX-120 1 C6800IA-48FPD 48 ports C6800IA 48GE POE Rev. 0.0"
NAME: "FEX-120 Chassis 2", DESCR: "FEX-120 Chassis 2"
PID: C6800IA-48FPD , VID: , SN: FOC2029Z4PV
NAME: "FEX-120 Chassis 2 PS 1 Built-in", DESCR: "FEX-120 Chassis 2 (power supply type 0.0.1.100)"
PID: Built-in , VID: , SN: DCB20196HEY
NAME: "FEX-120 Chassis 2 fan-tray 1 Built-in", DESCR: "FEX-120 Chassis 2 FEX FAN 0752 4800RPM(max)"
NAME: "FEX-120 Chassis 2 2 ", DESCR: "FEX-120 2 C6800IA-48FPD 48 ports C6800IA 48GE POE Rev. 0.0"
NAME: "FEX-121 Chassis 1", DESCR: "FEX-121 Chassis 1"
PID: C6800IA-48FPD , VID: , SN: FOC2029Z4LS
NAME: "FEX-121 Chassis 1 PS 1 Built-in", DESCR: "FEX-121 Chassis 1 (power supply type 0.0.1.100)"
PID: Built-in , VID: , SN: DCB20196HCT
NAME: "FEX-121 Chassis 1 fan-tray 1 Built-in", DESCR: "FEX-121 Chassis 1 FEX FAN 0752 4800RPM(max)"
NAME: "FEX-121 Chassis 1 1 ", DESCR: "FEX-121 1 C6800IA-48FPD 48 ports C6800IA 48GE POE Rev. 0.0"
NAME: "FEX-121 Chassis 2", DESCR: "FEX-121 Chassis 2"
PID: C6800IA-48FPD , VID: , SN: FOC2029Z4NZ
NAME: "FEX-121 Chassis 2 PS 1 Built-in", DESCR: "FEX-121 Chassis 2 (power supply type 0.0.1.100)"
PID: Built-in , VID: , SN: DCB20196C6H
NAME: "FEX-121 Chassis 2 fan-tray 1 Built-in", DESCR: "FEX-121 Chassis 2 FEX FAN 0752 4800RPM(max)"
NAME: "FEX-121 Chassis 2 2 ", DESCR: "FEX-121 2 C6800IA-48FPD 48 ports C6800IA 48GE POE Rev. 0.0"
NAME: "FEX-122 Chassis 1", DESCR: "FEX-122 Chassis 1"
PID: C6800IA-48FPD , VID: , SN: FOC2029V0NE
NAME: "FEX-122 Chassis 1 PS 1 Built-in", DESCR: "FEX-122 Chassis 1 (power supply type 0.0.1.100)"
PID: Built-in , VID: , SN: DCB202361TL
NAME: "FEX-122 Chassis 1 fan-tray 1 Built-in", DESCR: "FEX-122 Chassis 1 FEX FAN 0752 4800RPM(max)"
NAME: "FEX-122 Chassis 1 1 ", DESCR: "FEX-122 1 C6800IA-48FPD 48 ports C6800IA 48GE POE Rev. 0.0"
NAME: "FEX-122 Chassis 2", DESCR: "FEX-122 Chassis 2"
PID: C6800IA-48FPD , VID: , SN: FOC2029Z4NF
NAME: "FEX-122 Chassis 2 PS 1 Built-in", DESCR: "FEX-122 Chassis 2 (power supply type 0.0.1.100)"
PID: Built-in , VID: , SN: DCB20196HEP
NAME: "FEX-122 Chassis 2 fan-tray 1 Built-in", DESCR: "FEX-122 Chassis 2 FEX FAN 0752 4800RPM(max)"
NAME: "FEX-122 Chassis 2 2 ", DESCR: "FEX-122 2 C6800IA-48FPD 48 ports C6800IA 48GE POE Rev. 0.0"
NAME: "FEX-130 Chassis 1", DESCR: "FEX-130 Chassis 1"
PID: C6800IA-48FPD , VID: , SN: FOC2029Z4LX
NAME: "FEX-130 Chassis 1 PS 1 Built-in", DESCR: "FEX-130 Chassis 1 (power supply type 0.0.1.100)"
PID: Built-in , VID: , SN: DCB20196HCW
NAME: "FEX-130 Chassis 1 fan-tray 1 Built-in", DESCR: "FEX-130 Chassis 1 FEX FAN 0752 4800RPM(max)"
NAME: "FEX-130 Chassis 1 1 ", DESCR: "FEX-130 1 C6800IA-48FPD 48 ports C6800IA 48GE POE Rev. 0.0"
NAME: "FEX-130 Chassis 2", DESCR: "FEX-130 Chassis 2"
PID: C6800IA-48FPD , VID: , SN: FOC2029Z4LW
NAME: "FEX-130 Chassis 2 PS 1 Built-in", DESCR: "FEX-130 Chassis 2 (power supply type 0.0.1.100)"
PID: Built-in , VID: , SN: DCB20196HCP
NAME: "FEX-130 Chassis 2 fan-tray 1 Built-in", DESCR: "FEX-130 Chassis 2 FEX FAN 0752 4800RPM(max)"
NAME: "FEX-130 Chassis 2 2 ", DESCR: "FEX-130 2 C6800IA-48FPD 48 ports C6800IA 48GE POE Rev. 0.0"
NAME: "FEX-131 Chassis 1", DESCR: "FEX-131 Chassis 1"
PID: C6800IA-48FPD , VID: , SN: FOC2029Z4LT
NAME: "FEX-131 Chassis 1 PS 1 Built-in", DESCR: "FEX-131 Chassis 1 (power supply type 0.0.1.100)"
PID: Built-in , VID: , SN: DCB20196HD3
NAME: "FEX-131 Chassis 1 fan-tray 1 Built-in", DESCR: "FEX-131 Chassis 1 FEX FAN 0752 4800RPM(max)"
NAME: "FEX-131 Chassis 1 1 ", DESCR: "FEX-131 1 C6800IA-48FPD 48 ports C6800IA 48GE POE Rev. 0.0"
NAME: "FEX-131 Chassis 2", DESCR: "FEX-131 Chassis 2"
PID: C6800IA-48FPD , VID: , SN: FOC2029Z4ME
NAME: "FEX-131 Chassis 2 PS 1 Built-in", DESCR: "FEX-131 Chassis 2 (power supply type 0.0.1.100)"
PID: Built-in , VID: , SN: DCB20196HDG
NAME: "FEX-131 Chassis 2 fan-tray 1 Built-in", DESCR: "FEX-131 Chassis 2 FEX FAN 0752 4800RPM(max)"
NAME: "FEX-131 Chassis 2 2 ", DESCR: "FEX-131 2 C6800IA-48FPD 48 ports C6800IA 48GE POE Rev. 0.0"
NAME: "FEX-131 Chassis 4", DESCR: "FEX-131 Chassis 4"
PID: C6800IA-48FPD , VID: , SN: FOC2029Z4MH
NAME: "FEX-131 Chassis 4 PS 1 Built-in", DESCR: "FEX-131 Chassis 4 (power supply type 0.0.1.100)"
PID: Built-in , VID: , SN: DCB20196HEB
NAME: "FEX-131 Chassis 4 fan-tray 1 Built-in", DESCR: "FEX-131 Chassis 4 FEX FAN 0752 4800RPM(max)"
NAME: "FEX-131 Chassis 4 4 ", DESCR: "FEX-131 4 C6800IA-48FPD 48 ports C6800IA 48GE POE Rev. 0.0"
NAME: "FEX-132 Chassis 1", DESCR: "FEX-132 Chassis 1"
PID: C6800IA-48FPD , VID: , SN: FOC2029Z4MC
NAME: "FEX-132 Chassis 1 PS 1 Built-in", DESCR: "FEX-132 Chassis 1 (power supply type 0.0.1.100)"
PID: Built-in , VID: , SN: DCB20196HEN
NAME: "FEX-132 Chassis 1 fan-tray 1 Built-in", DESCR: "FEX-132 Chassis 1 FEX FAN 0752 4800RPM(max)"
NAME: "FEX-132 Chassis 1 1 ", DESCR: "FEX-132 1 C6800IA-48FPD 48 ports C6800IA 48GE POE Rev. 0.0"
NAME: "FEX-132 Chassis 2", DESCR: "FEX-132 Chassis 2"
PID: C6800IA-48FPD , VID: , SN: FOC2029Z4MR
NAME: "FEX-132 Chassis 2 PS 1 Built-in", DESCR: "FEX-132 Chassis 2 (power supply type 0.0.1.100)"
PID: Built-in , VID: , SN: DCB20196HFZ
NAME: "FEX-132 Chassis 2 fan-tray 1 Built-in", DESCR: "FEX-132 Chassis 2 FEX FAN 0752 4800RPM(max)"
NAME: "FEX-132 Chassis 2 2 ", DESCR: "FEX-132 2 C6800IA-48FPD 48 ports C6800IA 48GE POE Rev. 0.0"
NAME: "FEX-132 Chassis 3", DESCR: "FEX-132 Chassis 3"
PID: C6800IA-48FPD , VID: , SN: FOC2029Z4M9
NAME: "FEX-132 Chassis 3 PS 1 Built-in", DESCR: "FEX-132 Chassis 3 (power supply type 0.0.1.100)"
PID: Built-in , VID: , SN: DCB20196HE3
NAME: "FEX-132 Chassis 3 fan-tray 1 Built-in", DESCR: "FEX-132 Chassis 3 FEX FAN 0752 4800RPM(max)"
NAME: "FEX-132 Chassis 3 3 ", DESCR: "FEX-132 3 C6800IA-48FPD 48 ports C6800IA 48GE POE Rev. 0.0"
DSU-C6816-CORE#
DSU-C6816-CORE#
DSU-C6816-CORE#
DSU-C6816-CORE#
DSU-C6816-CORE#
DSU-C6816-CORE#
DSU-C6816-CORE#
DSU-C6816-CORE#
DSU-C6816-CORE#
DSU-C6816-CORE#
DSU-C6816-CORE#
DSU-C6816-CORE#
DSU-C6816-CORE#
DSU-C6816-CORE#
DSU-C6816-CORE#
DSU-C6816-CORE#
DSU-C6816-CORE#
DSU-C6816-CORE#show mod fex 131
Switch Number: 131 Role: FEX
Mod Ports Card Type Model Serial No.
1 48 C6800IA 48GE POE C6800IA-48FPD FOC2029Z4LT
2 48 C6800IA 48GE POE C6800IA-48FPD FOC2029Z4ME
4 48 C6800IA 48GE POE C6800IA-48FPD FOC2029Z4MH
Mod MAC addresses Hw Fw Sw Status
1 00a2.89de.4700 to 00a2.89de.4733 0.0 Unknown 15.2(3m)E6 Ok
2 d42c.4426.f680 to d42c.4426.f6b3 0.0 Unknown 15.2(3m)E6 Ok
4 00a2.89de.3300 to 00a2.89de.3333 0.0 Unknown 15.2(3m)E6 Ok
Mod Online Diag Status
1 Pass
2 Pass
4 Pass
DSU-C6816-CORE#
DSU-C6816-CORE#
DSU-C6816-CORE#
DSU-C6816-CORE#
DSU-C6816-CORE#
DSU-C6816-CORE#
DSU-C6816-CORE#
DSU-C6816-CORE#
DSU-C6816-CORE#
DSU-C6816-CORE#
DSU-C6816-CORE#
DSU-C6816-CORE#
DSU-C6816-CORE#
DSU-C6816-CORE#
DSU-C6816-CORE#
DSU-C6816-CORE#
DSU-C6816-CORE#remote command fex 131 show switch
Switch/Stack Mac Address : 00a2.89de.4700
H/W Current
Switch# Role Mac Address Priority Version State
*1 Master 00a2.89de.4700 15 4 Ready
2 Member d42c.4426.f680 14 4 Ready
3 Member 0000.0000.0000 0 0 Removed
4 Member 00a2.89de.3300 12 4 Ready
DSU-C6816-CORE#
01-03-2017 12:08 PM
I recently performed a software upgrade on several 6880 switches with attached 6800IA clients. Of the six 6880 switches two of them had 6800IA clients that did not boot up. We had to manually power cycle the IA clients to get them to boot. I was at the console of one of them and saw that it was stuck at initializing the fan controller.
We've had issues in the past with software upgrades. Apparently there is a bus on the 6800IA switches that gets in a bad state (IIC or ICC, I forget which). There is no way to know if it is in this state, but when the switch reloads you see odd symptoms. One is that that the switch doesn't boot, another is that it complains that your hardware is not authentic. In all cases doing a hard power cycle of the switch seems to be the solution. It's also a good idea to leave the power off for a little bit, I gave it 30 seconds to make sure that it was completely powered down.
Its also possible that the switch didn't get the software completely downloaded and rebooted. There was a field notice about this. It results in the switch stuck at rommon with no bootable image. Apparently the default image distribution method deletes the existing image before it downloads the new one. So if the 6800IA rebooted for some reason as the image was downloading, it has no bootable image. In newer versions it seems that the software is downloaded before deleting the old image.
http://www.cisco.com/c/en/us/support/docs/field-notices/638/fn63838.html
https://supportforums.cisco.com/discussion/12195911/6800-ia-upgrade-loop-6880-x-w-151sy
01-03-2017 12:47 PM
Ethan,
Thank you for the information! Ultimately we RMA'd the switch back to Cisco as it would not boot up after multiple attempts at powering it off and back on manually. I read through the field notice you referenced and found some good information that helped me fix another issue with a 6800ia that was caused by a bad image download. Thanks again for the feedback!
