09-15-2016 07:35 AM - last edited on 03-25-2019 01:32 PM by ciscomoderator
Hello Tidal Admins,
I need to make a SQL query that can give me a list of jobs that run on a particular day (Sunday) from 7am-12pm. Our environment does not have a maintenance window. So every time there is patching or upgrades, it causes more work and risk of Tidal job failures. By moving jobs out of the Sunday 7am-12pm timeframe, patching can be completed without interrupting the schedule.
Im not the best at SQL scripting and can not get my script to work. any help would be great. below is what I have so far. I get error ' the multi-part identifier jobmst.jobmst_name cant be found. Im using Tidal 6.0.3 with a SQL table for the Admeral DB.
SELECT dbo.jobdtl.jobdtl_id, dbo.jobmst.jobmst_prntname,dbo.jobmst.jobmst_name
FROM dbo.jobdtl INNER JOIN
dbo.jobmst ON dbo.jobdtl.jobdtl_id = dbo.jobmst.jobdtl_id
WHERE (dbo.jobdtl.jobdtl_fromdt > '09/14/2016 06:00:00 am') AND (dbo.jobdtl.jobdtl_fromdt < '09/11/2016 012:00:00 pm')
GROUP BY dbo.jobdtl.jobdtl_id, dbo.jobmst.jobmst_prntname, dbo.jobmst.jobmst_name
Solved! Go to Solution.
09-16-2016 05:44 AM
Hi Jeff
The time window from the jobdtl will only return jobs that have an Early Start Time and Late Start Time windows, so there may be some jobs defined that are not time bound but have dependencies on other jobs, variables, etc.
Below are 2 SQL queries against the jobrun table and jobmst:
--To list out jobs that ran last Sunday between 7:00am and 12:00pm
SELECT jobmst.jobmst_prntname, jobmst.jobmst_name, jobrun.jobrun_time FROM jobrun
JOIN jobmst on jobrun.jobmst_id = jobmst.jobmst_id
WHERE jobrun.jobrun_time >= '9/11/2016 7:00 AM' and jobrun.jobrun_time <= '9/11/2016 12:00 PM'
ORDER BY jobrun.jobrun_time
--To list out jobs that are scheduled to run this coming Sunday between 7:00am and 12:00pm
SELECT jobmst.jobmst_prntname, jobmst.jobmst_name, jobrun.jobrun_esttime FROM jobrun
WHERE jobrun.jobrun_esttime >= '9/18/2016 7:00 AM' and jobrun.jobrun_esttime <= '9/18/2016 12:00 PM'
ORDER BY jobrun.jobrun_esttime
BR,
Derrick Au
09-16-2016 05:44 AM
Hi Jeff
BR,
Derrick Au
09-16-2016 05:57 AM
Derrick. You are the man. I really appreciate all your feedback and assistance you give to us in this forum.
I'll be adding this query to my list.
09-16-2016 09:58 AM
Hi Jeff
Always a pleasure to share knowledge, and help whenever and wherever I can
Cheers
Derrick Au
