09-15-2016 10:39 AM
Hi all,
Can anyone please clarify the difference between these 2 commands?
vpn(config)# crypto ipsec security-association lifetime seconds 2147483647
vpn(config)# crypto map Test 1 set security-association lifetime seconds 2147483647
CF
Solved! Go to Solution.
09-15-2016 11:46 AM
The first one changes the default for all your VPNs, the second only for the peer that is referenced in sequence 1.
09-15-2016 11:46 AM
