09-16-2016 12:42 PM - edited 03-08-2019 07:27 AM
On our production N7K, the current kickstart and system images versions are n7000-s2-kickstart.6.2.12.bin & n7000-s2-dk9.6.2.12.bin. I'd like to upgrade both of them to version 7.3.0.
Can I jump from version 6.2 to version 7.3 without having to perform a sequential upgrades(6.2.14 & 6.2.16)?
Thanks in advance.
Best, ~zK
Solved! Go to Solution.
09-16-2016 03:10 PM
Hi;
As per upgrade path of Cisco Nexus 7K Upgrade:
For ISSU upgrade for 7.3 the switch should have min. 7.2(1) or 7.2(0) NXOS, while you can upgrade 7.2(0) from 6.2(12)
Means for you need to do multiple upgrade in ISSU scenario 6.2(12) -> 7.2(0) -> 7.3.
Note: before plan any thing please verify your scenario is support ISSU upgrade or not.
If you planing for Non-ISSU / disruptive upgrade then you can directly upgrade 7.3 from 6.2(12) via changing boot sequence of Nexus OS and reload switch.
Please find the detail in below link:
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/7_x/nx-os/release/notes/7x_nx-os_release_note.html#pgfId-1285078
Thanks & Best regards;
09-19-2016 01:13 PM
Hi;
No, need to issue the command multiple time. Per chassis required install all command 1 time & it will automatically upgrade the software on line card and FEX. If you use parallel keyword you can save your time otherwise switch will upgrade software sequential.
One more thing you can do before activity to verify the hardware/software incompatibility or impact (either disruptive/non-disruptive upgrade)
For software incompatibility— show incompatibility-all system image_filename
09-16-2016 03:10 PM
Hi;
09-16-2016 04:01 PM
Thanks for the info, Ahmed! That's very helpful.
So, I can use ISSU 7.2(0)D1(1) to upgrade from 6.2(12) to 7.2(0)D1(1) and, then, I will need to use ISSU 7.3(0)D1(1) to upgrade from 7.2(0)D1(1) to 7.3(0)D1(1), is that correct?
Thanks in advance.
Best, ~zK
09-17-2016 12:03 AM
Hi;
Yes.
Before plan a upgrade, please read the ISSU caveats. If you current network don't support ISSU then you can go directly to 7.3(0)D1(1) instead of multiple upgrade.
09-19-2016 11:56 AM
Got it.
I'm planning on using the sw#:install all kickstart image system image parallel command on a dual supervisor chassis. The chassis has 8 modules(2 SUPs and 6 line cards) in addition to 10 FEXs. I reviewed the below document and it states that "Up to three linecards can be upgraded in parallel with this command." Do you know if the parallel command will upgrade all of the line cards and FEXs or I will have to issue the commands several times?
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/6_x/nx-os/upgrade/guide/b_Cisco_Nexus_7000_Series_NX-OS_Software_Upgrade_and_Downgrade_Guide_Release_6-x.html
Best, ~zK
09-19-2016 01:13 PM
Hi;
09-19-2016 01:21 PM
Great!
Thank you so much for all your help. Much appreciated.
Best, ~zK
10-24-2016 03:02 PM
Hi Ahmed,
I ran the sh install all impact system bootflash:n7000-s2-dk9.7.2.0.D1.1.bin command and the output states that the two SUPs aren't compatible with the 7.2(0)D1(0) version. The current OS on the chassis is
BIOS: version 2.12.0
kickstart: version 6.2(12)
system: version 6.2(12)
Do you know why the image is incompatible with the SUPs only?
NX7K# sh install all impact system bootflash:n7000-s2-dk9.7.2.0.D1.1.bin
Installer will perform impact only check. Please wait.
Verifying image bootflash:/n7000-s2-kickstart.6.2.12.bin for boot variable "kickstart".
[####################] 100% -- SUCCESS
Verifying image bootflash:/n7000-s2-dk9.7.2.0.D1.1.bin for boot variable "system".
Performing module support checks.
Verifying image type.
Extracting "system" version from image bootflash:/n7000-s2-dk9.7.2.0.D1.1.bin.
Extracting "kickstart" version from image bootflash:/n7000-s2-kickstart.6.2.12.bin.
Extracting "bios" version from image bootflash:/n7000-s2-dk9.7.2.0.D1.1.bin.
Extracting "lc1n7k" version from image bootflash:/n7000-s2-dk9.7.2.0.D1.1.bin.
Extracting "fexth" version from image bootflash:/n7000-s2-dk9.7.2.0.D1.1.bin.
Notifying services about system upgrade.
Compatibility check is done:
Module bootable Impact Install-type Reason
1 no n/a n/a Incompatible image
2 no n/a n/a Incompatible image
3 yes non-disruptive rolling
4 yes non-disruptive rolling
5 yes non-disruptive rolling
6 yes non-disruptive rolling
7 yes non-disruptive rolling
8 yes non-disruptive rolling
101 yes non-disruptive rolling
102 yes non-disruptive rolling
103 yes non-disruptive rolling
104 yes non-disruptive rolling
105 yes non-disruptive rolling
106 yes non-disruptive rolling
107 yes non-disruptive rolling
108 yes non-disruptive rolling
111 yes non-disruptive rolling
112 yes non-disruptive rolling
113 yes non-disruptive rolling
114 yes non-disruptive rolling
115 yes non-disruptive rolling
116 yes non-disruptive rolling
117 yes non-disruptive rolling
118 yes non-disruptive rolling
Not all components in the image are compatible.
ISSU can't continue
Thanks in advance.
~zK
10-25-2016 02:31 AM
Hi;
I am guessing the error message you received is due to either you have SUP2 and image you download for SUP2E or vise versa.
Can you verify the supervisor module you have and download the right image (SUP2/SUP2E) and try it again?
As per image name and size both are showing same but Cisco is putting 2 different image on website that's why it's come to my min.
