09-20-2016 12:11 PM - edited 03-19-2019 11:36 AM
All,
What type of proactive monitoring do you recommend for CUCM, UCCE, Unity Connection, QM, Telepresence, IM&P, & CER? I.E Services, Utilization, etc
What Monitoring platforms are you using? Does anyone monitor their voice environment via Solarwinds?
Thanks.
09-20-2016 06:19 PM
Hi Adan,
You may check the Prime Collaboration Assurance option as described in detail in the following links
http://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/prime-collaboration/datasheet-c78-734833.html
http://docwiki.cisco.com/wiki/Setting_up_Devices_for_Prime_Collaboration_Assurance#Required_Protocols_for_the_Devices
Manish
09-22-2016 08:53 AM
This is great info! Thanks Manish!
