09-20-2016 02:59 PM - edited 03-17-2019 06:22 PM
One of our users is having the issue of his Cisco Jabber call notification appearing off screen. He is using version 11.1. He is running 3x monitors. 2x @ 2560x1140 and 1x @1920x1080. The main display is set as the center monitor. When someone calls the notification appears under the taskbar on the center display and must be drug up in order to answer the calls. Is this due to 3x displays? That they are different resolutions? I am not finding much doing searches for this.
09-20-2016 03:26 PM
I guess the easiest way to find that out would be to simply disconnect the secondary monitors, and see if the behavior changes, or remains the same.
I use a 2 or 3 monitor setup, depending where I am, and they are all "almost" the same resolution, but I've had no problems with the call notification.
09-21-2016 06:04 AM
