09-21-2016 02:12 AM - edited 03-01-2019 12:53 PM
Hi Guys ,
Firstly , thanks in advance for your comments .
I'm a cisco worker .
A client bought UCS C-460 with 12 SSD , 3TB each . It got no RAID controller, it is just JBOD .
I'm trying to install RHEL 7.2 on it , like the user asked [he asked that 100GB will go to " / " , and keep the rest un allocated ]
I have some issues with it .
I installed it , but something went wrong ... don't know what ...
the installation seems to be fine , but after the reboot , nothing booted up ...
I suspect that some configuration via CIMC is wrong .
please take a look on the screenshot , and let me know and if it's fine , and if you can aim me to something that I might did wrong .
thanks a lot !
Solved! Go to Solution.
09-21-2016 11:11 AM
Greetings.
Since boot disk is larger than 2TB, you are required to use UEFI.
Please make sure you have the following:
You may need to reinstall again, if it wasn't set to UEFI.
Kirk....
09-21-2016 11:11 AM
Greetings.
Kirk....
