ESA Content filters combination
Roger Base
I have 5 content filters on my ESA appliance. All of them work well if there is only one recipient in the email. The difference between my rule number 4 and 5 are that I am checking "rcpt-to-dictionary-match" domains on my rule 4.
The problem is when user sends email to many different email address/domains. The ESA are then only looking for the first rcpt and not for individual rcpt s. So If the first recipient in mail matches my rule number 4 then all other rcpts will also be matches same policy. Is there any way to get the ESA to handle all the rcpts individually ?
Hi Roger,
That is correct, the content filters would be executed based on first match. However, it would continue to be scanned by the other content filters as long as a final action is not defined. skip-filters() would be a final action for content filters.
If an email is sent to recipients @gmail.com, @xv.com and @xy.com
Policy 1
Sender Any
Recipient @xv.com,@xy.com
Default policy
Sender Any
Recipient Any
The original email would be split into two, first with @xv.com and @xy.com and the second for gmail.com
This is what the tracking and logs would look like
Wed Sep 21 12:19:48 2016 Info: MID 151 ICID 148 From: <unknown@unknown.com>
Wed Sep 21 12:19:48 2016 Info: MID 151 ICID 148 RID 0 To: <test@xv.com>
Wed Sep 21 12:19:49 2016 Info: MID 151 ICID 148 RID 1 To: <test@gmail.com>
Wed Sep 21 12:19:49 2016 Info: MID 151 ICID 148 RID 2 To: <test@xy.com>
Wed Sep 21 12:19:50 2016 Info: MID 151 Subject 'Test'
Wed Sep 21 12:19:50 2016 Info: MID 151 ready 284 bytes from <unknown@unknown.com>
Wed Sep 21 12:19:50 2016 Info: MID 151 was split creating MID 152 due to a per-recipient policy Policy 1 in the outbound table
Wed Sep 21 12:19:50 2016 Info: MID 152 ICID 0 From: <unknown@unknown.com>
Wed Sep 21 12:19:50 2016 Info: MID 152 ICID 0 RID 0 To: <test@xv.com>
Wed Sep 21 12:19:50 2016 Info: MID 152 ICID 0 RID 1 To: <test@xy.com>
Wed Sep 21 12:19:50 2016 Info: MID 151 was split creating MID 153 due to a per-recipient policy DEFAULT in the outbound table
Wed Sep 21 12:19:50 2016 Info: MID 153 ICID 0 From: <unknown@unknown.com>
Wed Sep 21 12:19:50 2016 Info: MID 153 ICID 0 RID 0 To: <test@gmail.com>
For the scenario described by you a new mail policy would need to be created with recipients mentioned in the dictionary with filter to check for the header and log entry.
The default policy would match the other recipients and check the header as required.
Hope this information helps.
Libin
6 Replies 6
Libin Varghese
Hi Roger,
An email (MID) would be processed as a whole by the matched content filter even if there are multiple recipients which do not match the filter condition.
The only way to work around this is using message splintering which is accomplished by using a separate mail policy.
For instance
Mail Policy 1: rcpt-to : gmail.com
Content Filter 1
Default Mail Policy: Any
Content Filter 2
Now an email with 2 recipients domain.com (would match default mail policy) and gmail.com (would match Mail Policy 1) would be split by the two mail policies and each content filter enabled on that mail policy would work.
Below KB for your reference
http://www.cisco.com/c/en/us/support/docs/security/email-security-appliance/118488-technote-esa-00.html
Libin
Hi Libin,
Will that mean that I will need to create 10 outgoing mail policy if I have 10 specific domains in rcpt-dictonary for policy 4. What will then happen if user sends same email to @gmail.com and @xv.com and @xy.com? ( and if I have outgoing mail policy for xy and xv domains? )
Here is my example of my Content filter 4 & 5. I am matching for the same header on both. in Policy4 I am also match for rcpt-to-dictinary-match for specific domain list.
Usecase:
So if the user sends a email to rcpt that are in my dictionary list it matches policy4. But if the person sends email to several rcpts. The ESA only consider the first rcpt in the email. There it will never match policy5 if the header is the same.
Hi Roger,
Policy 1
Sender Any
Default policy
Sender Any
Recipient Any
Libin
Thanks for quick reply Libin!
So I have created new Outgoing Mail Policy with 10 domains in it as recipients. I still have my Default Policy below which should work as "catch all" . And I have added Policy4 to my new Outgoing Mail Policy (and not for the default Policy). and Now I need to test it: I hope this solve my problem. I will update the case tomorrow.
Roger Base
It works :)
Glad to hear. :)
