Context Directory Agent - Querying AD fails
Ella Bella
So I have a brand new CDA deployed and patches 1 thru 5 all applied successfully.
I am attempting to connect with a Server 2012 R2 AD server, but am having some troubles.
My CDA AD user is a member of the domain-admins and I have also changed the permissions/ownership on both registry key's (and child objects) as per the CDA setup guide.
The error that I am currently seeing in CDA is:
ADObserver Error Querying for WMI property
When I expand the error I see the following:
Log attributes
wmi-property
exception-stack
org.jinterop.winreg.smb.JIWinRegStub.winreg_OpenHKCR(JIWinRegStub.java:134)
org.jinterop.dcom.core.JIComServer.initialise(JIComServer.java:509)
org.jinterop.dcom.core.JIComServer.<init>(JIComServer.java:445)
com.cisco.cda.rt.adobserver.adobserver.jinteropUtil.getWmiLocator(jinteropUtil.java:42)
com.cisco.cda.rt.adobserver.adobserver.EventsThread.QueryWMIProperty(EventsThread.java:81)
com.cisco.cda.rt.adobserver.adobserver.EventsThread.getNetBIOS(EventsThread.java:172)
com.cisco.cda.rt.adobserver.adobserver.EventsThread.extractDCData(EventsThread.java:204)
com.cisco.cda.rt.adobserver.adobserver.EventsThread.run(EventsThread.java:610)
dc-hostname
xxxxx-p1.xxxx.xxxxx.com.au/192.168.183.10
dc-name
xxxxx-AD
exception-cause
jcifs.smb.SmbException: The system cannot find the file specified.
wmi-class
Win32_NTDomain
exception-message
Message not found for errorCode: 0xC0000034
wmi-property
DomainName
dc-username
cda
Can anyone shed any light on this situation? Thanks!
Shay Elisha
Hi Ella,
run services.msc
Locate the 'Remote Registry service' on the list, and click "Start this service."
Shay
Shay Elisha
Hi Ella,
run services.msc
Shay
Shay, Thankyou so much. I was tearing my hair out!!
The official installation document for CDA does not mention anything about requiring remote registry service. It might be a good idea to add it in!
