09-24-2016 09:06 AM - edited 03-12-2019 01:19 AM
Hello, everybody!
Could anybody tell me whether can I set up a configuration on ASA like this:
I have two core switches cat4506 linked together over VSS, but they are located in different rooms.
May I connect asa5525 to them, using etherchannel link (two gigE stplit together)?
The second question is may I split this portchannel link in subinterfaces? I have several VLANs...
Many thanks in advance,
Ilya
Solved! Go to Solution.
09-24-2016 10:38 AM
Yes
yes
Please remember to select a correct answer and rate helpful posts
09-24-2016 10:38 AM
Yes
yes
