09-25-2016 04:44 AM - edited 07-05-2021 05:52 AM
Hai
we have one customer with 5508 sso,
its connected to two edge switches then edge
connected to core all trunk ,core is the DHCP
server.The issue is clients can get ip
but no traffic pass outside gateway at core.
no error logged. Tested different switches same.
It was working before .
Entiire network works on LAN , no issues
anybody face similar issues
09-25-2016 05:15 AM
To be honest, we have seen this also:) What I would check is that nothing has really changed as in our case something did.
These are some things I typically verify first. The last bullet point will eliminate if the wireless is the issue or not.
You also didn't mention your setup, local mode or flex and what controller, controller version and AP's you have.
-Scott
09-27-2016 03:24 AM
Thanks for reply , I found only problem with
apple devices, windows and android good.
using 5508 country code kw , tried US
code 8.0.120
any one had this issue
multicast enabled , tried with wireless n and Ac still iPhone and mac getting ip from dhcp
but no data flow outside , 5508 in local mode
thank you
09-27-2016 06:04 AM
Well since it is only with Apple devices, post your show WLAN <WLAN ID> so we can see how your SSID is setup.
If you test with an open SSID, does the Apple device work? That will eliminate at least the controller and point to your other SSID
-Scott
09-28-2016 12:27 AM
Hai
thanks for reply , I tried removing security making it open, still not working, I have only one SSID,I will
send it soon
thank you
09-28-2016 01:09 AM
Hai please find attached full config, please note only apple devices issue and from apple mac cannot ping even management interface of controller ,only ssid mapped interface can be ping.
windows, android all good.
thanks for all support, please help this strange issue
09-28-2016 06:12 AM
I don't see any attachment.
-Scott
10-05-2016 09:19 PM
Thanks for all posts
I was able to solve it by changing country and some practices mentioned here
Thank you
http://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-2/b_Enterprise_Best_Practices_for_Apple_Devices_on_Cisco_Wireless_LAN.pdf
https://supportforums.cisco.com/document/12068941/common-apple-ios-and-cisco-wireless-related-issues
