09-25-2016 01:19 PM - edited 03-08-2019 07:34 AM
Hello people !
I need some help concerning connecting Cisco switches with defined vlans to a hub, which is causing some vlan mismatch warnings, in addition to some vlan unusual behaviour.
In order to provide the same data to 2 different PCs ClientA (vlan 1) and ClientB (vlan 11) from PCSource, we did the following:
- Connected PCSource to a hub,
- Connectected port 13 of G-SW1 to the hub.
interface FastEthernet0/13
switchport mode access
- Connected port 13 of G-SW2 to the hub and assigned this port to vlan11
switchport access vlan 11
- G-SW1 connects via a trunk to switch R-SW1.
- G-SW2 connects via a trunk to switch R-SW2.
- ClientA is connected to port 1 of the R-SW1
spanning-tree portfast
-Similarly ClientB is connected to port 1 of the R-SW2, but assigned to vlan11:
I found two problems with this architecture:
- I have repetitive NATIVE_VLAN_MISMATCH in switch G-SW1 such as:
%CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on FastEthernet0/13 (1), with GBF-BVS7-SW2 FastEthernet0/13 (11).
- I can ping from ClientB to ClientA, where I thought that using vlan11 on the SW2 side will isolate the traffic between PCSource and ClientA from the traffic between PCSource and ClientB.
I tried to know also what are the recommandations concerning configuring Cisco switches ports when they are connected to a hub, but the only indication that I found was to not use spanning-tree portfast.
I would be grateful if you can help me with some advices.
09-25-2016 05:48 PM
I think this is for school work.
Kindly move this to the Cisco Learning Network.
09-25-2016 11:29 PM
Dear Lea,
09-26-2016 12:29 AM
I don't believe this is happening in a "production system" and still believe this is school work.
Yes, kindly move this line of questioning to the Cisco Learning Network.
09-26-2016 06:22 AM
Dear Leo,
I didn't know how to move the topic to Cisco Learning Network, so I created the same topic there:
https://learningnetwork.cisco.com/thread/101328
If you don't believe it is happening in a production system, it is your problem.
