Is there a way to have a VPN Client appear as if they are on the local LAN ?
Samuel DeMarco
Currently my local LAN is 192.168.100.xxx
My VPN clients are on 192.168.101.xxx
My devices on the local LAN cannot broadcast to the VPN LAN.
Is there a way to make the VPN Clients get an IP address of the Local LAN or appear as though they are on the local LAN?
Marvin Rhoads
You can define the VPN address pool to be a subset of the local LAN subnet.
I'm not sure why you need them to broadcast though. If the VPN and routing is properly setup, they should be able to reach all necessary remote addresses.
