09-27-2016 05:30 AM - edited 03-19-2019 11:37 AM
I need to configure my cisco ASA 5505 for working with Jabber.We got any connect licenses.
Certain users would then connect from jabber on their Android/iphone and connect to network. Major purpose is to use the call manager calling.
Can you please let me know the configuration required on ASA and the prerequisites.
We are on 8.2(5) version.
Vaibhav
09-27-2016 05:51 AM
You refer to the links below:
http://www.cisco.com/c/dam/en/us/products/collateral/security/asa-5500-series-next-generation-firewalls/guide_c07-717020.pdf
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/10_5/CJAB_BK_D6497E98_00_deployment-installation-guide-ciscojabber/deployment_scenarios.html
Hope this helps!
Aseem
(Please rate if useful)
10-10-2016 02:37 AM
Hi Aseem,
I just bought a any connect plus term license but i am seeing any connect essentials as disabled. Do we need to do any configuration to make it get enabled.
Current output
AnyConnect for Mobile : Enabled
AnyConnect for Cisco VPN Phone : Enabled
AnyConnect Essentials : Disabled
Advanced Endpoint Assessment : Enabled
thanks
Vaibhav
03-08-2017 12:20 PM
Hi All,
My VPN is sorted out , jabber works on Android but not on iPhone.
is there any different configuration which is needed for it to work.
Thanks in advance!!
