09-27-2016 06:19 AM - edited 03-17-2019 08:12 AM
Dear ,
when
VoIP_HiwaGroup(config-telephony)#create
Creating CNF files
CNF-FILES: Clock is not set or synchronized, retaining old versionStamps
VoIP_HiwaGroup(config-telephony)#do show clock
*14:29:27.830 UTC Tue Sep 27 2016
VoIP_HiwaGroup(config-telephony)#do show run | be tele
telephony-service
max-ephones 45
max-dn 30
ip source-address 10.2.2.1 port 2000 secondary 172.16.10.19
auto assign 1 to 3
system message Hiwa Rauf Investment
max-conferences 8 gain -6
moh en_bacd_music_on_hold.au
multicast moh 239.1.1.1 port 16384 route 10.2.2.1 172.16.10.19
web admin system name admin secret 5 $1$1veQ$gJLjXaoRe9YZDo7Y656D41
dn-webedit
time-webedit
transfer-system full-consult
after-hours block pattern 1 100
after-hours day Fri 08:00 23:00
create cnf-files version-stamp Jan 01 2002 00:00:00
V
Solved! Go to Solution.
09-27-2016 09:29 PM
Can you make sure that NTP is configured and synchronized in your CME. Share the output of 'show ntp ass'
09-27-2016 07:10 AM
This is the Video Over IP community, please move to IP Telephony.
09-27-2016 09:29 PM
09-27-2016 11:46 PM
thanks , I enabled
11-04-2021 07:05 PM
I have the same problem but I can't solve it. Could you help me with the commands to activate the ntp, please
