09-28-2016 12:59 AM - edited 03-14-2019 04:35 PM
Hi folks,
In UCCE11 Lab setup, am trying to display Customer Name and information on Cisco Finesse Agent desktop. Is it possible to create ECC variable with name "user.ecc.CustomerName"
Do I need I need to add ECC variable in ICM?
Can we pass Customer Name which is available in Outbound Dialer List (where Outbound lead is stored).
regards,
Ritesh Desai.
09-29-2016 01:55 PM
Yes create ECC variable in ICM, yes you can pass customer name/buddy name in outbound to the desktop.
david
09-30-2016 06:17 AM
Thanks David for your revert.
Referring to Finesse document, there is nothing much I could understand regards to custom variable. request you to share HINTS! :)
In my lab setup I have configured 2 ECC's.
Nothing worked out. Data is not displayed.
I've Cisco SIP Dialer in which I've defined Column1 as FirstName in Import Rule .txt file. Can we display the customer name in Finesse desktop OR can we pull data from import rule uploaded in system.
Motive is to achieve what is the name of customer who has answered.
As you said, is Buddy name refered as FirstName in SIPDialer?
regards,
Ritesh Desai.
