09-29-2016 02:09 AM
We had a 'stuck device' on LMS - showed as offline, no reference to device anywhere else - so rebooted the server. This was done after stopping daemon manager.
When it booted back up, 3 of the processes are showing as administratively shut down:
CTMLrmServer, DataPurge and DFCTMStartup. Trying to start these results in them stopping almost immedialtey.
Can anyone shed any light?
output from PDshow brief below
Process State Pid
RMEDbEngine Program started - No mgt msgs received 15846
ANIDbEngine Program started - No mgt msgs received 15889
ESS Program started - No mgt msgs received 15918
EssMonitor Running normally 15952
EventFramework Program started - No mgt msgs received 15964
MACUHIC Running normally 15965
UTLITE Running normally 15966
SyslogCollector Running normally 15968
IpmDbEngine Program started - No mgt msgs received 15969
UPMDbEngine Program started - No mgt msgs received 16129
UPMDbMonitor Running normally 16162
DFMLogServer Program started - No mgt msgs received 16164
DFMCTMStartup Administrator has shut down this server 0
FHPurgeTask Transient terminated 0
DfmBroker Running normally 16166
DfmServer Running normally 16258
DfmServer1 Running normally 16259
FHDbEngine Program started - No mgt msgs received 16260
INVDbEngine Program started - No mgt msgs received 16502
PMServer Running normally 16545
EPMDbEngine Program started - No mgt msgs received 16574
EPMServer Running normally 16650
AdapterServer Program started - No mgt msgs received 16723
AdapterServer1 Program started - No mgt msgs received 16724
FHServer Running normally 16725
DFMMultiProcLogger Program started - No mgt msgs received 16726
CSDiscovery Transient terminated 0
DCRDevicePoll Transient terminated 0
CSRegistryServer Running normally 16728
Tomcat Program started - No mgt msgs received 16730
TomcatMonitor Running normally 16952
Apache Running normally 17647
LicenseServer Program started - No mgt msgs received 17648
FDRewinder Never started 0
NameServer Program started - No mgt msgs received 17649
NameServiceMonitor Running normally 17730
EDS Running normally 17772
CmfDbEngine Program started - No mgt msgs received 17944
CmfDbMonitor Running normally 17977
DCRServer Running normally 17981
CMFOGSServer Program started - No mgt msgs received 18041
TISServer Program started - No mgt msgs received 18042
DFMOGSServer Program started - No mgt msgs received 18100
NOSServer Running normally 18185
PTMServer Running normally 18186
InventoryCollector Running normally 18189
Interactor Program started - No mgt msgs received 18312
InventoryCollector1 Program started - No mgt msgs received 18313
Interactor1 Program started - No mgt msgs received 18413
UPMProcess Running normally 18414
IPMOGSServer Program started - No mgt msgs received 18415
ANIServer Running with busy flag set 18416
UTMajorAcquisition Never started 0
WlseUHIC Running normally 18563
UTManager Running normally 18564
VNMServer Program started - No mgt msgs received 18565
EssentialsDM Running normally 18567
ICServer Running normally 18689
EnergyWise Running normally 18788
ConfigMgmtServer Running normally 18789
PMCOGSServer Program started - No mgt msgs received 18790
ConfigUtilityService Running normally 18791
EDS-GCF Running normally 18792
jrm Running normally 18793
DataPurge Administrator has shut down this server 0
IPMProcess Program started - No mgt msgs received 19262
CTMJrmServer Administrator has shut down this server 0
ChangeAudit Never started 0
SyslogAnalyzer Never started 0
1816 Never started 0
1815 Never started 0
1814 Never started 0
diskWatcher Running normally 20334
09-29-2016 06:41 AM
Hi ,
Try these steps , hope it will help:
1. Stop the daemon manager by issuing the following command: > net stop
crmdmgtd
2. Go to Start > Settings > Control Panel > Administrative Tools > Services.
3. Change the Windows services so that only the following CiscoWorks
services are set to Automatic, the rest must be set to Manual: ( THESE are the correct settings, if it is already correct then Ignore it)
- CW Daemon Manager Automatic
- CWCS rsh/rcp service Automatic
- CWCS syslog service Automatic
- CWCS tftp service Automatic
4. Please, reboot the server.
5. As the Daemon Manager Service is set to "Automatic", it will start after
the reboot. Please, wait for about 10 minutes before logging into the LMS,
in order to wait for all the processes to come up properly. Please, log into
the application and let me know if the issue is still present.
If not working fine try the following:
1. Open a command line in the CiscoWorks server.
2. Go to the following path:
NMSROOT#\Program Files\CSCOpx\setup\support
3. In this path, please type as follows:
resetCasuser.exe
4. Then, the next will be displayed:
Please select the following option to proceed.
1. Randomly generate casuser password.
2. Enter casuser password.
3. Exit.
Please enter a valid option:
5. Choose option 1.
*** Remember to restart Daemon Manager after this:
NMSROOT# net stop crmdmgtd
NMSROOT# net start crmdmgtd
After this please reboot the server, wait for 10 min before login to LMS
again , and make sure that you are logged in as Administrator when doing
these procedures.
Thanks-
Afroz
***Ratings Encourages Contributors ***
09-30-2016 03:19 AM
Thankyou Afroj.
Missed an important point out - Its running on a VM - not Windows.
EDIT:
Log info showing a log4j error.
log4j:ERROR Could not connect to remote log4j server at [localhost]. We will try again later. java.net.ConnectException: Connection refused at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:351) at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:213) at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:200) at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366) at java.net.Socket.connect(Socket.java:529) at java.net.Socket.connect(Socket.java:478) at java.net.Socket.(Socket.java:375) at java.net.Socket.(Socket.java:218) at org.apache.log4j.net.SocketAppender.connect(SocketAppender.java:203) at org.apache.log4j.net.SocketAppender.activateOptions(SocketAppender.java:160) at org.apache.log4j.config.PropertySetter.activate(PropertySetter.java:256) at org.apache.log4j.config.PropertySetter.setProperties(PropertySetter.java:132) at org.apache.log4j.config.PropertySetter.setProperties(PropertySetter.java:96) at org.apache.log4j.PropertyConfigurator.parseAppender(PropertyConfigurator.java:654) at org.apache.log4j.PropertyConfigurator.parseCategory(PropertyConfigurator.java:612) at org.apache.log4j.PropertyConfigurator.parseCatsAndRenderers(PropertyConfigurator.java:533) at org.apache.log4j.PropertyConfigurator.doConfigure(PropertyConfigurator.java:417) at org.apache.log4j.PropertyConfigurator.doConfigure(PropertyConfigurator.java:441) at org.apache.log4j.helpers.OptionConverter.selectAndConfigure(OptionConverter.java:470) at org.apache.log4j.LogManager.(LogManager.java:122) at org.apache.log4j.Category.getInstance(Category.java:519) at com.cisco.nm.xms.ctm.registry.CTMRegistryStarter.(CTMRegistryStarter.java:15)
Cheers
Alun
