09-29-2016 03:24 AM - edited 03-18-2019 12:08 PM
Dears,
i am installing cucm 11.5.1-11900 on a VM on BE6000M,
the installation is interrupted with rpm issue.
find attached the error.
any idea plz?
best regards,
chawki dib
09-29-2016 04:06 AM
Is this Publisher or Subscriber?
Can you grab install logs, refer below for procedure
http://www.cisco.com/c/en/us/support/docs/unified-communications/unity-connection/116577-technote-UC-00.html
09-29-2016 04:52 AM
Hi ,
this is the publisher first installation.
I can not access the VM right now.
put it seems that this is a global issue,since many friends told me that they had this issue too.
and also if you want to do the upgrade from version 10 to version 11.5 (same issue).
best regards,
chawki dib
09-29-2016 05:01 AM
Check if you match the symptoms of below defect
CSCvb00248 CUC/CUCM 11.5(1) does not support passwords longer than 15 characters
Install logs will reveal exact root cause.Grab them share it here.
