Cisco AnyConnect Secure Mobility client - connecting to multiple VPN on same machine
hitesh_mehta
Hi ,
How do I connect to multiple clients via VPN using Cisco's Anyconnect secure mobility client on the same laptop ?
Thanks .
Hitesh
Marvin Rhoads
Just select the VPN profile from the drop down list. Profiles are populated following an initial connection, as long as they have been configured at the remote end.
If the remote site administrator has not configured a profile, you can instead type their VPN gateway's FQDN or IP address in the VPN tile.
