Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1930181members
1245762discussions
Community Activity
How Do I Get a Human at 𝐀merican 𝐀irlines Immediately??~QUICK~SUPPOR
 hone assistance: One of the quickest ways to speak with a 퐀퐦퐞퐫퐢퐜퐚퐧 support agent is by callingퟭ-ퟖퟕퟕ ✈ ퟓퟓퟗ ✈ 0161 // ퟭ-ퟖퟕퟕ ✈ ퟓퟓퟗ ✈ 0161 . The phone number for 퐀퐦퐞퐫퐢퐜퐚퐧 assistance is listed on their official website. Simply call the number and follow ...
Cisco Catalyst 9600 - Factory Reset
Hi all,I have locked myself out of the switch, more specifically, I can't enable. Every method of password recovery I have tried has failed. I do not know how to factory reset my two stackwise-enabled switches. I need a password recovery procedure th...
IP connectivity between Nexus and Palo Alto firewall
I'm struggling to understand connectivity problem between a switch and firewall.  The Nexus is located between the Core switch and the edge firewall. It's purpose is to divert traffic via ITD for content filtering.  My problem right now is that I'm n...
jeff20 by Level 1
  • 421 Views
  • 26 replies
Monitoring of Catalyst/DNA Center itself
Hi,I wonder which is the best way to monitor our DNA Center appliance. We have all our networking infrastructure monitored and we want to have DNA Center also under this tool (from SolarWinds). We usually monitor using icmp and SNMP. Is it possible t...
lecabral by Level 1
  • 74 Views
  • 3 replies
How to configure a user for SNMP configuration on ESA ?
I want to monitory ESA devices on Zabbix. So I've configured snmp on ESA with snmpconfig command but Zabbix need a userID define so that it can pull all data not only icmp(ping). And there is no UserID settings defined/request during snmpconfig comma...
Givara B by Level 1
  • 727 Views
  • 1 replies
C9500 Core
Hi, I have a site that has two C9500 as Cores and they have Dell Powerconnect 7024 ver 5.1.18.1 connected with the Core, the issue we are seeing is that the uplinks are not coming seen by the C9500. Just wanted to ask if someone has seen this issue. ...
CML sandbox availability problem
In the past Devnet sandbox, the maximum reservation duration is 4 hours and I usually didn't have much problem accessing the CML sandbox. However, in the new Torque system, the maximum reservation duration is up to 8 days. It is almost impossible to ...
VPN route-based unable to ping remote IP
Hi, I am currently encountering issue on route-based ipsec vpn. I cannot ping my remote IP also the remote tunnel. I have verified that there is no decap showing on packets. I already configured static route between each site and still unsucessful of...
Web Application Server
Dear Community,I'm asking for you guidance. I have come across a challenge on Cisco ASA version 9.8. Need to allow a web server to be access outside(Public) from DMZ Zone to Ouside Zone.  Per below configuration template. Nat is transilating but acce...
dissai by Level 1
  • 335 Views
  • 14 replies
