CMS WebRTC
j.huizinga
Level 6
Level 6
I have installed CMS with a demo key in my lab. I can do some video conferencing with Cisco IP phones and jabber clients.
I am now trying to configure WebRTC (Web bridge). I get the login menu:
But when I try to login I get the error as seen in the screen shot.
The user is imported from LDAP in CMS (Status/users) and is vissible. Also the XMPP status seems OK:
Any help would be apreciated
Jan
Yep, that was it
Needs SRV records
10 Replies 10
Patrick Sparkman
What appears in the XMPP logs, as well as the CMA logs?
I would double check the CMS Configuration Guides and make sure you have everything setup as it should be, possibly something with the XMPP server isn't setup correct.
Thanks Patrick
Where would I find the XMPP  and the CMA log files?
In CMS I see only the event logs
Jan
Hi , did you solve it? I have the same problem. Regards
OP's issue was due to a missing _xmpp-client SRV record. See a few replies down from yours, and you'll see he found and fixed the issue.
Hi, sorry for the delay and thanks for your answer. So I understand its a dns problem , but I also have some doubts about configuration , can you help me:
I have a cms server running with hostname cms1 and domain domain.com ip 10.186.99.34
I have AAA records internal  to resolve this fqdn : cms.domain.com
I have srv records pointing to that fqdn:
DNS SRV record for _xmpp-server._tcp for port 5269 resolving to cms1.domain.com
and
DNS SRV record for _xmpp-client._tcp for port 5222 resolving to cms1.domain.com
in cms cli I have:
ptlissvcms> xmpp
Enabled                 : true
Clustered               : false
Domain                  : join.domain.com
Listening interfaces    : a
Key file                : acanolab.key
Certificate file        : acanolab.crt
Max sessions per user   : unlimited
STATUS                  : XMPP server running
ptlissvcms> xmpp callbridge list
Callbridge : acanolabcb
Secret     : xpto
ptlissvcms>
ptlissvcms> dns
VM DNS Configuration
    "status": "running",
    "forward zones": [
            "domain name": "domain.com",
            "server ip": "10.186.99.50"
            "server ip": "10.186.99.54"
            "domain name": ".",
            "domain name": ".",
    "User configured RRs": [
        "_xmpp-client._tcp.join.domain.com. 120 IN SRV 10 10 5222 join.domain.com."
Web bridge settings
Guest account client URI: https://join.domain.com
Guest account JID domain: join.domain.com
And in CMS WEB GUI -> Configuration I have:
XMPP server settings
Unique Call Bridge name : acanolabcb
Domain: join.warpcom.com  ->
Server address : 10.186.99.34:5223
But when I query DNS in CMS CLI I got no results:
ptlissvcms> dns lookup SRV _xmpp-client._tcp.domain.com
Trying _xmpp-client._tcp.domain.com
DNAME:        cms1.domain.com.
PRIORITY:     10
WEIGHT:       10
PORT:         5222
DNSSEC SECURE:NO
A RESULTS FOR cms1.domain.com.
Trying cms1.domain.com.
10.186.99.34 (IS NOT DNSSEC SECURE)
AAAA RESULTS FOR cms1.domain.com.
No results
ptlissvcms>
I think its because my confusion about join.domain.com and domain.com , i try to use internally different domain because domain.com its used for S4B environment.
Hi , for now the problem is solved with creation of 2 srvs xmp_client and xmpp_server , and the change of xmpp domain to domain.com in Cli and Web GUI.
When I SFTP to the CMS I see a log file, and when I check after a login failure I see:
INFO : login request received - session:0 user:1 password:1
INFO : Session 7FAF06E34020 activated - 1 currently active
INFO : No DNS SRV records for _xmpp-client._tcp.home.local
INFO : XMPP connection dropped while session was live for reason 2
INFO : Session 7FAF06E34020 moving from state idle to disconnected
INFO : XMPP connection dropped while session was live for reason 0
INFO : Session 7FAF06E34020 moving from state disconnected to disconnected
INFO : Session 7FAF06E34020 destroyed (0 active, cumulative 1)
Seems that an SRV record is required, I shall do some extra reading
Jan
Yep, that was it
Needs SRV records
hi  huizinga2
I too see the same issue ,, i am using  CMS app and  WebRTC to  login  internally from  local lan, but could not  login.  the  error as shown above . iam in   single split server setup,,,  my  SRV  record  points to  loadbalancer  internal  interface a  IP address .
_xmpp-client._tcp.moj.gov.sa     -  5222    resolve to--  internal ip address of  loadbalancer _xmpp-server._tcp.moj.gov.sa  --5269  -   resolve to  -internal ip address of load balancer
below are the errors is see in edge server  ....additionally ..
Even though ldap sync is complete ,,but i dont see any users listed   under  :STATUS -> Users...
Dec 6 14:48:11 user.info cmsedge webbridge: INFO : Session 7F3B02BC5020 activated - 1 currently active
Dec 6 14:48:14 user.info cmsedge webbridge: INFO : XMPP connection dropped while session was live for reason 1
Dec 6 14:48:14 user.info cmsedge webbridge: INFO : Session 7F3B02BC5020 moving from state idle to disconnected
Dec 6 14:48:14 user.info cmsedge webbridge: INFO : XMPP connection dropped while session was live for reason 0
Dec 6 14:48:14 user.info cmsedge webbridge: INFO : Session 7F3B02BC5020 moving from state disconnected to disconnected
Dec 6 14:48:14 user.info cmsedge webbridge: INFO : Session 7F3B02BC5020 destroyed (0 active, cumulative 1)
well there was some issue with  filter part in Ldap section !
take care with space id ,,and filter  with out this  cms will not work.
