Trying to setup the CSPC
Jason Thomas
Good morning, I just downloaded and deployed the CSPC OVA template. However when I boot it up and try to use the username and password provided in the documentation here: https://supportforums.cisco.com/blog/12696871/self-service-onboarding-setting-cspc-25-collector namely user: admin, password: Admin!23 it does not work and says login incorrect.
Does anyone know the password?
Thank you!
7 Replies 7
Lynden Price
Hi Jason,
That should be the correct username/password. What is the filename of the OVA you deployed?
Lynden
This is the file name: SNTC-CSPC2.6.1-RC1-OVF10.ova
Neither admin/Admin!23 or admin/Admin123 work.
Sorry, I think the login should be Admin#123. See page 9 here http://www.cisco.com/c/dam/en/us/td/docs/net_mgmt/inventory_and_reporting/CSPC_Getting_Started_Guide_2-5.pdf
The credentials admin/Admin#123 did not work in the console either. I cannot login to configure the IP's to see if Admin#123 would work in the web GUI.
Hi Jason,
The collector prompts you to change the password when you first log in. It could be that it was accidentally changed when you first did the deployment. I'd suggest deploying a new OVA and try to log in again.
Lynden
The latest version uses
U: admin
P: Admin#123
Jason Thomas
Thank you all for your help. It turns out that admin/Admin!23 did eventually work, however the VMware console has issues with Linux OSes sometimes. So the characters may not have been sent correctly to the console. I had to type the password very slow and wait about a second between each key press to get it to accept the password.
