10-05-2016 07:39 AM - edited 03-18-2019 06:27 AM
I have CTS-PHD-2.5X, just wondering if i could just connect it via USB to a PC and use it with WebEx?
10-05-2016 08:56 AM
No, your PC will not recognize it as a video capture device. Cisco doesn't create Windows drivers for it.
If you view the camera guide, you will see the USB port is labeled "for future use"
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/camera/precisionhd/user_guide/precisionhd_1080p-720p_camera_user_guide.pdf
10-07-2016 12:26 AM
Is there anyway to use it with webEx?
10-07-2016 04:13 AM
The camera is only usable when connected to a codec - it's just an input device. If it's connected to an SX20 or something like that it can dial into a Webex CMR meeting, but if you are trying to use the camera by itself with a Webex client, no.
10-07-2016 04:32 AM
I have a SX20. Is there a guide anywhere that can show me how to do this?
10-07-2016 07:50 AM
If you have WebEx Meeting Center with CMR Cloud feature, than you can dial into the meeting via a video conference endpoint or application.
10-05-2016 09:14 AM
It's not possible to use a camera meant for a TelePresence endpoint to be used as a webcam with a computer.
