Cannot communicate with the server(Jabber MRA)
Nishad Ismail
We recently changed the public IP of the Cisco Expressway ,All the necessary changes is done
  • Expressway-E configured the Single NIC deployment
  • NAT Reflection configured
  • Traversal Zones is active with Public  IP
  • SRV record in the Public DNS is working
  • Internally Jabber is working fine
While accessing from internet getting error"Cannot communicate with the server" jabber for windows
While accessing from internet getting error"Cannot locate server" jabber for Android
attached the logs for the Diagnostic logs for expressway core and edge ,Error report logs for the jabber for windows
10 Replies 10
Jaime Valencia
And what did you find while reviewing the logs??
java
if this helps, please rate
Cheers
Andre
I have the same problem, Jabber discovers the services over MRA, but cannot sign in. If I enter wrong password, it gives me "Wring password". The command xConfiguration did not help. Please, help!!
Andre Castro
What happens if you try to login with the wrong password?
What is the Expressway version you are running?
When I am giving Wrong password giving me error "Your username or password is not correct"
Expressway version :8.8.1
CUCM version 11.x
From the X8.8 on, reverse DNS is required to be properly configured.
You have the same symptom I got myself a couple of days ago.
As a workaround you can disable reverse DNS verification running the command on both Exp-E and Exp-C:
xConfiguration XCP TLS Certificate CVS EnableCvs: Off
Andre Castro
Had the same issue. Thanks!
Thanks bro, you saved my weekend.
Great Info. Many Thanks
Andre,
Thank you!
This temp fix worked for me so I could keep services up until my server admins update the DNS records for reverse lookup.
