Best way to upgrade to version CSR1000V 03.16.04.aS
fatdrag0n
patch file? package?
Is this the instruction?
http://www.cisco.com/c/en/us/td/docs/routers/csr1000/software/configuration/csr1000Vswcfg/swupgradecsr.html
New server launch and moving config might take more time!
What's the best practice fastest way?
neidlein.p
Same here,
Notes
The Cisco CSR 1000.bin upgrade file cannot be used to upgrade the release version of AMIs obtained from Amazon Web Services. You must create a new AMI instance and migrate your configuration and license(s).
is not so convenient
