Attendant Console Standart auto Logged into Hunt Group
mesut ozcan
Dear all,
At a customer, we are using Attendant Console Standart. If the user shut down his PC at evening, attendant console application logged out automatically. It is normal. If the user power on his PC, the Attendant Console application needs to logged in automatically. But it does not work so.
Then if the user not logged into hunt group, dont get calls and i need to login CUCM page and logged the phone into hunt group.
There is lots of user with same application abut only one user face this issue.
Does anyone have any idea about that?
Best Regards,
Mesut
Jonathan Schulenberg
Add a shortcut for Attendant Console client to the Startup folder of that user's Start menu. This will put the app in the user's face when they login to their computer each morning. If they minimize it and don't log in then you have a user who doesn't want to do their job.
