10-12-2016 07:40 AM
I'd like to create a report based on users and their access to Web-Based Email sites.
Since there is a Filter Category for this - I thought I could pull one from a Attribute in Reporting - but there doesn't seem to be the attribute I'm looking for.
Any Ideas?
10-12-2016 05:24 PM
You can do this by going to:
Reports -> Search -> Detailed Search -> Add Filter -> Select Filter Type to Attribute Filter -> Select Attribute as Category -> Select operator is equal to -> enter " Web-based Email"
Then you can launch search
If you need to filter further based on certain user, you can add more filter like the above using:
"User is equal to <the name of the user>"
10-13-2016 06:45 AM
That worked great... thanks..
