10-18-2016 12:33 AM
I am trying to upload SEP{MAC}.cnf.xml file to an updated third-party cp-8851
I know I need to configure option 150 and point it to my TFTP server - but the phone is ignoring this and does not connect to the TFTP for the configuration
The only way I communicate with the TFTP is through provisioning (which I used to upgrade to the latest firmware)
What am I doing wrong?
Asaf
10-18-2016 12:36 AM
1. Factory-default the phone?
2. Did the phone get a valid IP address? Can the TFTP server ping the phone's IP address?
3. On the phone logs, what are the error message?
10-18-2016 12:40 AM
Thanks for the fast reply
1. How do I factory-default the phone?
2. The phone is able to communicate with the TFTP server - This is how I upgraded the firmware
3. No error on the phone logs or the TFTP server - Seems like it does not request the SEP{mac}.cnf.xml file at all
10-18-2016 12:51 AM
The phone needs to be factory-reset in order for the phone to start requesting for the SEPmacaddress.cnf.xml.
The procedure to factory-reset the phone is:
1. Press "#" when you power on the phone
2. You will see the headset,speaker and mute will light on and then light off.
3. When you see only headset and speaker turn on again, please press 123456789*0# in sequence.
4. After you pressed the the first digit "1", you will see speaker turn off.
5. After all the number are input completely in sequence, you will see Mute button turns on to indicate phone begin to do the factory reset.
Don't forget to appropriately rate useful posts.
10-18-2016 04:23 AM
I have managed to factory reset it but it is the same
Seems like it is try to provision (I got the same error while provisioning is on)
The TFTP server log is
Connection received from 192.168.11.14 on port 50935 [18/10 14:19:58.475]
Read request for file <8851-3PCC.xml>. Mode octet [18/10 14:19:58.477]
File <8851-3PCC.xml> : error 2 in system call CreateFile The system cannot find the file specified. [18/10 14:19:58.478]
Connection received from 192.168.11.14 on port 51758 [18/10 14:19:58.500]
Read request for file <Cisco/CP-8851-3PCC/0041d2f9d792.cfg>. Mode octet [18/10 14:19:58.501]
File <Cisco\CP-8851-3PCC\0041d2f9d792.cfg> : error 2 in system call CreateFile The system cannot find the file specified. [18/10 14:19:58.502]
Connection received from 192.168.11.14 on port 50998 [18/10 14:19:58.530]
Read request for file <8851-3PCC.xml>. Mode octet [18/10 14:19:58.531]
File <8851-3PCC.xml> : error 2 in system call CreateFile The system cannot find the file specified. [18/10 14:19:58.531]
Connection received from 192.168.11.14 on port 52581 [18/10 14:19:58.549]
Read request for file <Cisco/CP-8851-3PCC/0041d2f9d792.cfg>. Mode octet [18/10 14:19:58.550]
File <Cisco\CP-8851-3PCC\0041d2f9d792.cfg> : error 2 in system call CreateFile The system cannot find the file specified. [18/10 14:19:58.550]
10-18-2016 01:31 PM
WTF!
What exact firmware was uploaded to the phone? 3PCC or SIP?
Try uploading the SIP firmware.
10-18-2016 02:11 PM
I am using 3pcc firmware since I am working against Asterisk PBX and not CUCM
The phone is able to register and work fine
I just need to fine tune a few settings that are not available through the web gui - aka line BLF, dial tone etc.
10-18-2016 02:27 PM
I know what you're trying to accomplish. I have a working Asterisk (Raspberry Pi) system working at home and I never use 3PCC firmware.
Downgrade to SIP because it's easier (for me) to troubleshoot what is going on.
This error message alone tells me 3PCC and SIP firmware behaves differently. This error message tells me the phone is looking for a filename called MACADDRESS.cfg (instead of the SIP method of SEPmacaddress.cnf.xml). This is the reason why the phone isn't downloading the correct configuration file.
10-18-2016 02:33 PM
Can you guide me which firmware file should I install?
It is half past midnight here so I will give it a try first thing in the morning
Hope that the sip firmware will be able to work correctly against Asterisk
10-18-2016 11:02 PM
My 7970 is running 9.4(2)SR1. Try that.
10-18-2016 11:19 PM
I am unable to change the firmware from 3ccp to sip...
The phone is downloading the files but not changing the firmware
10-18-2016 11:22 PM
Copy the SEPmacaddress.cnf.xml to 0041d2f9d792.cfg.
11-09-2016 09:19 AM
Login in to the phone's web interface.
Select admin and then advanced
select the provisioning tab
In the profile rule, fill in where to find your provisioning server
click submit all changes -> phone will resync with your provisioning server.
But I haven't yet come across any parameter that's not configurable from the web interface.
For BLF - again, admin/advanced - phone tab
and the configuration is not that different to the SPA phones.
If you don't have the box available to fill in the fnc=blf+cp+sd -> then upgrade the firmware. (to the latest available 3pcc image)
Please do not upgrade our your phone to the enterprise version. You do not want this for your Asterisk machine and it's a one way move. Don't do it else you'll need to but a new phone.(or call manager)
Adam
11-10-2016 01:40 AM
Thank you for you comment
I am using the latest version
I am trying to configure the spare line keys as BLF
(the client needs on 3 keys)
There is an option to configure extension unit but this is not what I am trying to achieve
Asaf
11-10-2016 02:34 AM
OK,
1. Search for 3pcc administration guide, failing that there SPA one is good too.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/csbpipp/ip_phones/administration/guide/frame_source/500-series-7-5-7/ip_phone_admin/2_linesandextensions.html
You need to configure on the Phone tab - extended function box for the button you want;
fnc= something; where something is SP (speeddial), CP (Call pickup) and BLF (presence)
eg. fnc=blf+cp+sd;
2. You then need to pass parameters to those functions
SUB = Subscribe address for the presence (BLF)
This will start the subscribe/notify sip messages
EXT = the number you want to dial for the speed-dial for that contact
NME = display name that appears on the LCD screen
You can also refer to other configuration parameters - eg $PROXY means the configured proxy server on ext0;
So an example could be:
fnc=blf+cp+sd;sub=my-user-i-want-to-subscribe-to@$PROXY;ext=12345@$PROXY;nme=My Users name;
or even using sip-uri's
fnc=blf+cp+sd;sub=julie.cox+voip.co.uk@$PROXY;ext=julie.cox+voip.co.uk@$PROXY;nme=Julie C;
For Call pickup, you must also configure the SIP Server type; and pickup code
look on ext0 - sip server type. Metaswitch is the same as the SPA RFC version.
look on "att console" and set the Call pickup code to the string that matches what the pbx is wanting.
If you don't have the extended function box, then you need newer firmware.
