VSS on 6800
Arjun Dabol
Hello Experts
1. Just a  quick check : the way we configure VSS on 6500 is it similar on 6800 (6880 / 6807) as well ?
2. Below is some VSL QoS setting for 6500 on cisco site - is it similar on 6800 also ?
  • VSL is a critical internal control and data communication path, and hence QoS settings are pre-configured and configuration changes are not allowed.
  • VSL is always configured as Trust CoS and ingress queueing is enabled.
  • Only CoS based trust and queuing is supported currently. Service policies are not supported on VSL.
  • QoS policies must be applied at the input interface of the flows.
  • Priority queue is enabled by default. VSS control traffic and BPDUs are given high priority on VSL link.
Any quick help is appreciated.
InayathUlla Sharieff
Arjun,
Its still the same. Its just the next branch of 6500 so all the things would still remain the same.
Some info on 6800 VSs:-
https://www.ciscolive.com/online/connect/sessionDetail.ww?SESSION_ID=76867
Inayath
